Custom domain stuck in delete state.
Chris Carter 20 Reputation points
2026-08-13T01:12:51.0466667+00:00
I have an Azure Static Web App custom domain, portal.southlandmd.com, that is permanently stuck in the Deleting state.
The original custom-domain creation failed with an unknown error.
I have already removed the DNS records and confirmed the hostname no longer resolves.
I have also attempted deletion through the Azure Portal, Azure CLI, and PowerShell. Azure accepts the delete operations and returns Static Sites operation-status URLs, but the custom-domain resource remains in Deleting with the same error.
This appears to be a stuck Azure Static Web Apps backend resource/state issue.
An Azure service that provides streamlined full-stack web app development.
Saritha Bandaru 665 Reputation points Microsoft External Staff Moderator
2026-08-13T01:50:39.3966667+00:00
Hello @chrischrischris
Thank you for your patience while we looked into this.
We have received confirmation that mitigation has been applied, and your custom domain issue should now be resolved. Could you please retry the operation and verify whether everything is working as expected?
If you are still experiencing any issues, please reply with an update and any relevant details. We will be happy to continue assisting you and investigate further if needed.
We look forward to hearing back from you.
Please "accept" if the information helped you. This will help us and others in the community as well.
0 additional answers
