How to fit empty startup
Steven Black 20 Reputation points
2026-08-12T06:47:48.8633333+00:00
when I go to settings and then go to apps/startup it's empty where there should be a list of disabled programmes and able programmes this has just recently happenedapps
Windows for home | Windows 11 | Apps
DaveM121 930.8K Reputation points Independent Advisor
2026-08-13T08:43:08.6066667+00:00
Did you ensure you downloaded the ISO in the exact same language version as you have set for the Windows user interface in the Settings App - Time and Language - Region and language, if that is English, is that US English or just English.
19 additional answers
  1. Steven Black 20 Reputation points
    2026-08-13T06:10:31.74+00:00
    When I clicked on to SEE THE ANSWER404
    it took me to 404 page https://learn.microsoft.com/en-us/answers/a/12911402SA
  2. Steven Black 20 Reputation points
    2026-08-13T06:19:37.51+00:00
    it just takes me to another 404 page https://learn.microsoft.com/en-us/answers/a/12911460
  3. DaveM121 930.8K Reputation points Independent Advisor
    2026-08-13T06:21:00.9733333+00:00
    This is a direct link to your question on Q&A, is this working correctly.
    https://learn.microsoft.com/en-us/answers/questions/5973094/how-to-fit-empty-startup
  4. Ankita 20 Reputation points
    2026-08-13T06:22:28.5966667+00:00
    In addition to Task Manager and the Startup folders, you can also check these locations:
    • Open Registry Editor (regedit) and review:
      • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
        • HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
        If the Startup Apps page is empty due to corrupted system files, run the following commands in Command Prompt (Admin):
        • Restart the PC after the scan and check Settings > Apps > Startup again.
        • If the issue started after a recent Windows update, installing the latest cumulative update or performing an in-place repair upgrade may restore the Startup Apps page.
    If you can share your Windows version (winver) and whether the Startup Apps page is completely blank or shows an error message, we can suggest more specific troubleshooting steps.
