APNs token-based (HTTP/2) credential validation consistently fails with generic "Failed to validate credentials with APNS" — resolved by switching to Certificate mode
Manoj Ramachandran 0 Reputation points
2026-08-12T02:59:05.7533333+00:00
Configuring a Notification Hub with token-based APNs authentication (.p8 key) consistently failed with:
BadRequest — Failed to validate credentials with APNS
This error gives no further detail client-side, across every interface tried:
  • Azure Portal (Apple (APNS) blade, Authentication Mode = Token)
  • Azure CLI (az notification-hub credential apns update)
  • Direct ARM REST PATCH with apnsCredential
What we verified was correct (to save others from re-checking the same things):
  • Key ID, Team ID, and Bundle ID all matched exactly what's shown in the Apple Developer portal
  • The Push Notifications capability was confirmed enabled on the App ID before generating the key (tried both before-enable and after-enable key generation — same failure either way)
  • "Broadcast Capability" (a sub-option under Push Notifications) was explicitly disabled — this can trip up validation in some setups
  • The .p8 token content was verified byte-for-byte, including the BEGIN/END PRIVATE KEY lines, with real newlines (not escaped \n sequences from a JSON export — a separate gotcha we also hit when configuring FCM v1, worth checking if you're pasting from a downloaded JSON key)
  • Tried against both api.development.push.apple.com and api.push.apple.com endpoints
  • Tried with a completely fresh key generated ~20 hours later, to rule out Apple-side propagation delay
  • Confirmed via the Portal's own "Change" validation too — same generic error, no additional detail surfaced
Resolution: Since our subscription doesn't have a paid support plan (so no way to open a technical ticket to see server-side logs), we switched to Certificate mode instead — generated an APNs SSL certificate (Sandbox & Production) via Apple Developer portal, built a .p12, and configured the hub with Authentication Mode = Certificate. This validated successfully on the first attempt, using the same App ID/Team ID that had failed repeatedly under token mode.
Posting in case anyone else hits the same wall — token mode is generally recommended over certificates (no annual renewal, works across multiple apps with one key), so if anyone from the product team can shed light on what specifically causes token-mode validation to fail silently like this, it'd help others avoid losing time chasing credential-formatting issues that turn out not to be the actual problem.Configuring a Notification Hub with token-based APNs authentication (.p8 key) consistently failed with:
Azure Notification Hubs
An Azure service that is used to send push notifications to all major platforms from the cloud or on-premises environments.
    2026-08-12T02:59:32.7033333+00:00
    Supported causes and checks from the available guidance are:
    • For APNS token-based authentication in Notification Hubs, the required fields are Key ID, Team ID, Bundle ID, Token, and the correct Endpoint.
    • The Token value must come from the Apple .p8 file, and the PEM header/footer must be stripped before supplying it to the Notification Hubs portal or API.
    • The Endpoint must match the app’s aps-environment entitlement. For token mode, valid values are:
      • https://api.development.push.apple.com:443/3/device
      • https://api.sandbox.push.apple.com:443/3/device
    • In Azure CLI, token mode uses:
      • --key-id
      • --app-id for the 10-character Team ID
      • --app-name for the application name or BundleId
      • --token
      • --endpoint
    • If notifications are not reaching devices, Notification Hubs guidance says to first verify that the platform credentials configured in Azure match the application registered in the platform developer account.
    • For APNS, guidance also states to keep separate hubs for production and testing and not mix different certificate types in the same hub, because that can cause notification failures.
    • For iOS 13 scenarios, silent notifications and requests using the apns-push-type header require token-based authentication. Certificate mode can still be configured, but token mode is the required path for those cases.
    The specific internal reason for a generic Failed to validate credentials with APNS response is not described in the available documentation.
    The documented token-format detail most likely to cause validation failure is that the .p8 private key value supplied to Notification Hubs must not include the BEGIN/END PRIVATE KEY PEM wrapper text.
    Certificate mode is a supported alternative configuration path in Notification Hubs:
    1. In the hub, go to Notification Services > Apple (APNS).
    2. Select Certificate.
    3. Upload the .p12 file.
    4. Enter the password if required.
    5. Select Sandbox or Production as appropriate.
    6. Save.
  2. Muhammad Bilal Khan 180 Reputation points
    2026-08-12T03:17:02.4366667+00:00
    Hey Manoj,
    Good catch on the deep dive, but I actually spotted the culprit in your troubleshooting steps! You mentioned verifying the token content including the BEGIN/END PRIVATE KEY lines. That is exactly what is breaking it.
    When configuring token-based APNs in Azure Notification Hubs, you have to strip out the PEM header and footer. Azure just wants the raw base64 string. Including those wrapper lines causes it to fail silently with that generic BadRequest error.
    If you ever want to switch back to Token mode (since it is way easier to maintain than dealing with .p12 certificate renewals), here is how the configuration should look.
    The Token Format
    Instead of pasting the whole file:
    -----BEGIN PRIVATE KEY-----
    MIGTAgEAMBMGByqGSM49AgEGCCqGSM49AwEHBHkwdwIBAQQg...
    -----END PRIVATE KEY-----
    You just pass the raw inner string:
    Azure CLI Configuration
    Since you mentioned trying the CLI, here is exactly how that command should look with the stripped token:
    az notification-hub credential apns update \
      --resource-group "YourResourceGroup" \
      --namespace-name "YourNamespace" \
      --notification-hub-name "YourHubName" \
      --key-id "ABC123DEFG" \
      --app-id "YOUR_TEAM_ID" \
      --app-name "com.yourcompany.bundleid" \
      --token "MIGTAgEAMBMGByqGSM49AgEGCCqGSM49AwEHBHkwdwIBAQQg..." \
      --endpoint "https://api.push.apple.com:443/3/device"
    Glad the Certificate mode got you unblocked for now, but hopefully, this saves you (and anyone else reading) a headache next time!
