DSC Local Configuration Manager Stuck in Busy State
Advait Mohammad 40 Reputation points
2026-08-11T05:42:49.8133333+00:00
We pushed a DSC configuration to a batch of Windows Servers, but the deployment was interrupted on several nodes. Since then, any attempt to apply a new configuration fails because the Local Configuration Manager (LCM) reports that it is still busy.
There are no active DSC jobs that we can see, so it looks like the LCM state was never properly released after the failed push.
What's the supported way to reset the LCM state and clean up any pending DSC configurations without having to reboot the affected servers?
Windows for business | Windows Server | User experience | PowerShell
  1. Domic Vo 32,865 Reputation points Independent Advisor
    2026-08-11T08:23:41.4833333+00:00
    When the Local Configuration Manager (LCM) gets stuck in a “busy” state after an interrupted DSC push, the supported way to clear it without rebooting is to explicitly reset the LCM job queue and remove any pending or partially applied configurations. You can do this directly from the console using PowerShell.
    First, check the current DSC job state with Get-DscConfigurationStatus. If it shows a job in progress but never completes, you can force a reset by stopping the DSC engine:
    Code
    Stop-DscConfiguration -Force
    This command clears any active or orphaned DSC job handles. Once that’s done, you should also remove any pending or corrupted configuration documents from the LCM store. Run:
    Code
    Remove-DscConfigurationDocument -Stage Pending -Force
    Remove-DscConfigurationDocument -Stage Current -Force
    Remove-DscConfigurationDocument -Stage Previous -Force
    This wipes out the stuck configuration documents from all stages. After that, reinitialize the LCM by reapplying a clean meta-configuration if needed:
    Code
    Set-DscLocalConfigurationManager -Path <path_to_meta_config>
    At this point, the LCM state machine is reset, the “busy” flag is cleared, and you can safely push a new DSC configuration without rebooting the server. This is the Microsoft-supported method for recovering from interrupted DSC deployments, and it avoids having to restart the node or reset unrelated system settings.
    I hope you've found something useful here. If it helps you get more insight into the issue, it's appreciated to accept the answer. Should you have more questions, feel free to leave a message. Have a nice day!
    Domic Vo.
