Not Responding
Dorinda Lewis 0 Reputation points
2026-08-11T00:59:07.5466667+00:00
Ive been playing Hoyle game for years on this computer, now when I open the game it , its saids not responding
  1. Emma1-N 12,285 Reputation points Microsoft External Staff Moderator
    2026-08-11T06:19:16.0733333+00:00
    Welcome Dorinda Lewis,
    I understand how frustrating it can be that Hoyle is showing " Not responding" when opening.
     To help narrow this down, could you please confirm:
    • Which version of Windows are you using? (Press Windows + R, type winver, and press Enter.)
    • Does the game freeze immediately when you open it, or does it reach the main menu first?
    • Did the issue start after a Windows update, game update, or any other recent change?
    In the meantime, please try these quick checks:
    Option 1: Restart the computer
    • Save any work and restart Windows completely
    • Then try opening Hoyle again
    Option 2: Run the game as Administrator
    • Right-click the Hoyle game shortcut
    • Select Run as administrator
    Option 3: Check for game compatibility issues
    • Right-click the Hoyle shortcut and select Properties
    • Open the Compatibility tab
    • Check Run this program in compatibility mode for and try an older Windows version if available
    Option 4: Repair the program (if the option exists)
    • Open Settings > Apps > Installed apps
    • Find the Hoyle game, select Advanced options (if available), then choose Repair. Microsoft provides guidance on repairing apps in Windows
    I hope the steps above help you deal with your issue.
    If the answer is helpful, please click "Yes". If you have extra questions about this answer, please click "Comment".
