Sudden problem in using the 'correct' function in Voice Access.
Elizabeth Pendleton 0 Reputation points
2026-08-10T21:06:36.9233333+00:00
Last night I suddenly experienced a problem when trying to use "correct that" in Voice Access. The problem affects both my desktop and laptop. The program will now offer me the numbered list of potential corrections, e.g. 1. My 2. my. But when I say "1", the word selected is highlighted in dark grey. It is not corrected at all - though the program thinks it has been, as at the top of the screen I see the number chosen and the option of Add to Vocabulary. This is a catastrophic fault. Given that Voice Access is not great at transcribing what I've said, I'm now left unable to correct the errors (other than using my fingers, which I need to avoid as much as possible). Other functions seem to be working normally.
Windows for home | Windows 11 | Accessibility
  1. Deleted
  2. Emma1-N 12,030 Reputation points Microsoft External Staff Moderator
    2026-08-11T02:42:03.2333333+00:00
    Welcome Elizabeth Pendleton,
    I understand how disruptive this is, especially if you rely on Voice Access to work hands-free. Since the issue started suddenly and is occurring on both your desktop and laptop, I'd like to narrow down whether this is related to Voice Access itself, a recent update, or a specific application.
    Could you please let us know:
    • Does this happen in all apps (such as Notepad, Word, and your web browser), or only in certain applications?
    • When you say "correct that", does the numbered list appear normally and only fail after you say the number?
    • Which Windows 11 version are you running? Press Windows + R, type winver, and share the version/build shown.
    • Have either device received a Windows update shortly before the issue began?
    As a quick test, please try the correction feature in Notepad:
    • Open "Notepad".
    • Turn on Voice Access and dictate a sentence with an intentional mistake.
    • Say"correct that" and then select one of the numbered suggestions.
    • Let me know whether the word is corrected in Notepad or if it is only highlighted.
    I look forward to your reply so we can continue working together to address the issue.
