Powerpoint issue
Anoop RS 20 Reputation points
2026-08-10T14:32:39.8333333+00:00
I am using Microsoft 365 Family edition. While working on Powerpoint, when selecting multiple objects the objects come along with cursor. Tried the Microsoft support, troubleshooting done uninstalled MS Office and reinstalled. They have tried using remote session. I have changed the Keyboard, Mouse, tried using mousepad changed moused almost done everything. Noting could help me. I am a presentation designer so the whole work relies on PPT. It's very annoying while working. Could anyone please help me on this.
AI answer
2026-08-10T14:33:02.6633333+00:00
Use this isolation path for PowerPoint on Windows, especially since reinstalling Office and changing mouse/keyboard hardware did not help:
  1. Check whether PowerPoint is busy with another process.
    • Look at the status bar at the bottom of the PowerPoint window.
    • If PowerPoint is in use by another process, wait for that task to finish before selecting or moving objects.
  2. Start PowerPoint in Safe Mode to test for add-in interference.
    • Press Start and type PowerPnt /safe, then open it.
    • If the problem does not happen in Safe Mode, an add-in is the likely cause.
  3. Disable add-ins.
    • In PowerPoint, go to File > Options > Add-Ins.
    • Select COM Add-ins and click Go.
    • Clear all check boxes to disable the add-ins, then click OK.
    • Restart PowerPoint.
    • If the issue is gone, re-enable add-ins one at a time, restarting PowerPoint each time, to identify the add-in causing the problem.
  4. Make sure Office is fully updated.
    • Open an Office app.
    • Go to File > Account.
    • Under Product Information, select Update Options > Update Now.
    • If Update Now is not shown, select Enable Updates first.
  5. Repair Office.
    • Close all Office apps.
    • Open Control Panel > Programs and Features.
    • Right-click Microsoft Office in the installed apps list.
    • Select Change > Repair.
  6. Try a Selective Startup in Windows.
    • This helps determine whether another background program is conflicting with PowerPoint.
    • If Selective Startup resolves the issue, another startup app or service is interfering.
  7. If the issue continues, send feedback from PowerPoint.
    • In PowerPoint, go to File > Feedback > Send a Frown.
    • Include diagnostic and usage data so the product team can analyze the issue.
The most relevant next step here is Safe Mode plus disabling add-ins, because a similar object-selection issue can be caused by an add-in even when reinstalling Office and changing input devices do not help.
0 additional answers
