Startups: Companies that are in their initial stages of business and typically developing a business model and seeking financing.
Hello @Kushal Bora , I hope you are doing well,
Welcome to Microsoft Q&A.
If you are developing an early-stage project independently and do not yet have an incorporated company, Azure for Students is likely the most appropriate Microsoft program if you meet its eligibility requirements.
Azure for Students provides $100 in Azure credits for 12 months and does not require a credit card. You must be a full-time student at an accredited degree-granting institution and verify your student status using your academic email address. ([Microsoft Learn](https://learn.microsoft.com/en-us/azure/education-hub/find-ids?utm_source=chatgpt.com"What is Azure for Students? | Microsoft Learn"))
Microsoft for Startups has different eligibility requirements. The current program is intended for startups developing software-based products or services that are owned by the company, and the company must be privately held and for-profit. Therefore, if you are currently an individual student without a company, Azure for Students would generally be the better fit. ([Microsoft Learn](https://learn.microsoft.com/en-us/azure/signups/startup-help?utm_source=chatgpt.com"What is Microsoft for Startups? | Microsoft Learn"))
You can review the official requirements here:
- Microsoft for Startups – Eligibility and application
- What is Azure for Students?
- Azure for Students FAQ
I would recommend using Azure for Students while you are in the student/project stage rather than incorporating a company solely to qualify for Microsoft for Startups.
If my answer helped you, please consider marking it as accepted. This helps others in the community find similar solutions.
