Microsft Designer Not Cropping...Photo Neither
Donna Bathalter 20 Reputation points
2026-08-09T17:04:49.0233333+00:00
My Microsoft Designer stopped cropping. I took your advise that I saw online and went to Photos. Same issue. I'm currently using Paint, but I truly like Microsoft Designer for its features. A good many people have pointed out this same issue. What is being done to fix the issue?
Windows for home | Windows 11 | Apps
AI answer
2026-08-09T17:05:03.39+00:00
There is no context indicating an announced fix timeline for this cropping issue in Microsoft Designer or Photos.
What is supported from the available information:
  1. In Microsoft Photos, cropping is available through Photos > open the photo > Edit image (Ctrl+E) > Crop. Photos supports preset aspect ratios, free rotation, and rotate/flip actions.
  2. In Designer from Photos, Edit with Designer can do crop, rotate, adjustments, filters, text, and background removal/blur.
  3. If Designer is not appearing or not working correctly in Photos, the documented requirements are:
    • open a single image first
    • be connected to the internet
    • use a supported language: English, Spanish, French, Portuguese (Brazil), German, or Italian
    • sign in with a Microsoft account for AI features; Microsoft Entra accounts are not supported for editing with Designer
  4. A Microsoft Q&A response for a similar Photos/Designer launch problem recommends repairing Microsoft Edge WebView2 Runtime:
    • Settings > Apps > Installed apps
    • find Microsoft Edge WebView2 Runtime
    • select Modify > Repair
    • restart the PC
If the goal is to report the cropping behavior itself rather than work around it, the available guidance is to submit feedback through Feedback Hub or the Feedback portal, since feature changes and backend fixes are not handled through support forum replies.
0 additional answers
