An implementation of Visual Basic that is built into Microsoft products.
Hello @Heinrich Morf ,
Thank you for reaching out.
It is possible to control when a worksheet calculates by adjusting the Excel calculation mode via VBA. To achieve this, it might be beneficial to set the application's overall calculation mode to "Manual". Once that is done, you can use VBA to trigger the calculation only for a specific worksheet exactly when you need it.
Below is a brief example of how you might set this up in your code:
Sub ControlWorksheetCalculation()
' 1. Turn off automatic calculation to prevent it from recalculating on every change
Application.Calculation = xlCalculationManual
' ... perform your data entry, formatting, or other VBA tasks here ...
' 2. Trigger calculation for a specific worksheet
' Replace "Sheet1" with the actual name of your worksheet
ThisWorkbook.Worksheets("Sheet1").Calculate
' (Optional) If you want to calculate all open workbooks instead, you would use:
' Application.Calculate
' 3. Turn automatic calculation back on when your tasks are complete (if desired)
Application.Calculation = xlCalculationAutomatic
End Sub
For more detailed context, you can refer to the official Microsoft documentation here:
I hope this informamation is helpful for your scenario. Please let me know if you are trying to implement this in a specific workflow or if you need any further details. If you found my response helpful or informative, I would greatly appreciate it if you could follow this guide for your confirmation.
Thank you.
