Intermittent Automatic Restart Issue When Selecting Shut Down in Windows 11
amralaa-8729 695 Reputation points
2026-08-06T23:48:07.11+00:00
Hi everyone,
I am experiencing an intermittent issue when trying to shut down my laptop:
Sometimes, after finishing my work and selecting Shut down from the Start menu, the system turns off briefly and then automatically reboots/restarts on its own instead of powering off completely.
System Details:
The issue is intermittent and does not happen every time.
Fast Startup is already disabled.
There are no Blue Screens (BSOD) or visible errors prior to or during shutdown.
I would appreciate any guidance on how to diagnose what is triggering these unexpected wake/restart events upon shutdown.
Thanks!
Emmanuel Santana 40,195 Reputation points Independent Advisor
2026-08-07T00:45:28.5266667+00:00
Hello. Immediately after this happens, open Event Viewer > Windows Logs > System. Around the shutdown time, do you see Event ID 41 (Kernel-Power), 6008, 1001, or 1074? If you see 1074, what does it show for "Shutdown Type" and the process that initiated it?
Also, try this:
Open Command Prompt as administrator and run:
shutdown /s /f /t 0
Does the laptop remain powered off when shut down this way, or does it still occasionally power itself back on?
0 additional answers
