Web App for container doesn't align with ABAC-mode registries
Baley Gregoire 10 Reputation points
2026-08-06T16:38:54.2166667+00:00
The Problem: Deployment Center Validation vs. ABAC Reality
  1. ABAC-enabled registries do NOT honor AcrPull
Per the ACR ABAC repository permissions documentation (https://learn.microsoft.com/en-us/azure/container-registry/container-registry-rbac-abac-repository-permissions):
Legacy ACR roles such as AcrPull, AcrPush, and AcrDelete are not honored in ABAC-enabled registries. Instead, use the Container Registry Repository Reader, Container Registry Repository Writer, and Container Registry Repository Contributor roles.
  1. App Service documentation still references AcrPull
The App Service custom container documentation (https://learn.microsoft.com/en-us/azure/app-service/configure-custom-container) still explicitly instructs assigning AcrPull:
az role assignment create --assignee
Azure Container Registry
An Azure service that provides a registry of Docker and Open Container Initiative images.
  1. Nithin 330 Reputation points
    2026-08-06T17:03:59.6833333+00:00
    Hi Baley,
    You are 100% spot on this is a genuine architecture gap between Azure App Service and ACR ABAC (Attribute-Based Access Control).
    Because App Service's managed identity pull agent relies on registry-level control-plane permissions (Microsoft.ContainerRegistry/registries/pull/read), it cannot negotiate repository-scoped ABAC tokens. Since ABAC-enabled registries disable legacy AcrPull entirely, managed identity pulls fail on both Portal and CLI.
    Here are the two working paths today:
    1. Use ACR Scoped Repository Tokens (Service Principal / Credential path): Instead of Managed Identity, create a Repository-Scoped Token in ACR with repository/read permissions and configure App Service using registry credentials:
      • Set DOCKER_REGISTRY_SERVER_USERNAME to your ACR token name.
      • Set DOCKER_REGISTRY_SERVER_PASSWORD to your token secret (stored securely in Azure Key Vault).
    2. Consider Azure Container Apps (ACA): If strict ABAC repository scoping + Managed Identity authentication is an absolute requirement for your architecture, Azure Container Apps natively supports fine-grained repository-scoped ACR pulls without requiring legacy AcrPull.
    Microsoft is tracking App Service support for ABAC registries. In the meantime, Repository Tokens are the recommended workaround for App Service.
    Ref: Azure Container Registry Repository-Scoped Tokens
    If this helps clarify the current limitation and workaround, please mark as Accept Answer!
  2. Baley Gregoire 10 Reputation points
    2026-08-07T07:18:13.1033333+00:00
    Hi Nithin,
    Thank you for this detailed answer!
    If this limitation is known why isn't it documented? I couldn't find any mention on this issue.
    Is there a roadmap to fix the issue? Could you share a resolution target date?
    I have another workaround because I want to avoid handling secret with weaker security level (we currently use it on several scope):
    1. Configure RBAC + ABAC with the needed level of right
    2. Add the old AcrPull RBAC (unused but unlock the webapp control-plane check)
    3. Wait for the fix to remove the AcrPull
    Best regards
  3. Baley Gregoire 10 Reputation points
    2026-08-07T10:12:36.8433333+00:00
    Hi Nithin,
    Best regards
  4. Baley Gregoire 10 Reputation points
    2026-08-07T10:12:53.44+00:00
    Hi Nithin,
    Best regards
