microsoft edge does not work,
Patrick Lenssen 0 Reputation points
2026-08-06T16:06:18.3966667+00:00
microsoft edge does not work, tried all tips , i have windows 10
Microsoft Edge | Open the browser | Windows 10
    2026-08-06T16:06:37.4933333+00:00
    Work through these in order, and test Edge after each step:
    1. End all Edge processes.
      • Press Ctrl+Shift+Esc to open Task Manager.
      • End every msedge.exe task.
      • Start Edge again.
    2. Try a temporary Edge profile to check whether the current profile is corrupted.
      • Open Command Prompt and run:
         "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --user-data-dir="%TEMP%\edge-test-profile"
      • If Edge opens with this test profile, the original profile is likely the problem.
    3. Create a new profile if the test profile works.
      • Close all Edge windows.
      • Go to %LOCALAPPDATA%\Microsoft\Edge\User Data.
      • Rename the Default folder to Default.old.
      • Start Edge again so it creates a fresh Default profile.
      • If Edge is stable, copy needed data such as Bookmarks from Default.old to the new profile.
    4. Repair Microsoft Edge.
      • Make sure Edge is closed for all users.
      • Go to Start > Settings > Apps > Installed apps.
      • Select Microsoft Edge > Modify > Repair.
      • This requires internet access and administrative rights. Browser data and settings should not be affected.
      • If Modify is unavailable, Edge may be managed by an organization and a system administrator is required.
    5. Check whether Edge is up to date.
      • If Edge opens, go to Settings and more > Settings > About Microsoft Edge and apply any available update.
    6. Restart Windows.
      • A running process can interfere with Edge. Restart the PC and test again.
    7. Check security software.
      • If third-party antivirus or security software is installed, update it and test Edge again.
    8. If Edge opens briefly but pages fail or crash:
      • Close other tabs, apps, and unnecessary extensions.
      • Clear browsing data from Settings and more > History > Open history page > Delete browsing data.
  2. GsN5034 - IA 76,895 Reputation points Independent Advisor
    2026-08-06T16:46:17.9466667+00:00
    Hello, thank you for reaching out to Microsoft Q&A.
    1. May I please know the exact error message you receive when you launch the Microsoft Edge app on your Windows 10 PC?
    2. Have you tried uninstalling and reinstalling the Microsoft Edge web browser?
    Meanwhile,
    May I please know the edition of the Windows 10 Operating system installed on your device?
    Type winver in the search bar on the taskbar and click Enter.
    Post a screenshot of the resulting dialog box.
