nvm all I had to do was turn touchpad on its fixed
Freezing Issue?
Avant Drummond
5
Reputation points
i finally got back into windows after the bitlocker bug i had for a few days, but now i have another issue. when i tried to turn off touchpad the whole thing froze. The mouse, everything. So I restarted the computer in an attempt to fix it but it took me to an option “choose how you want to sign in” but I can’t because my mouse is frozen still, so I might be soft locked
How to fix this
Windows for home | Other | Search, touch, and mouse
1 additional answer
AI answer
2026-08-05T18:52:02.9633333+00:00 - First check the mouse/touchpad hardware basics:
- If using a USB mouse, unplug it, wait briefly, then plug it back in.
- Try a different USB port.
- If a USB hub is in use, remove it and connect the mouse directly to the PC.
- If the device is wireless, reconnect the receiver or use the device reset button if available.
- Make sure the device has power or fresh batteries.
- Since the system is freezing, test whether Windows is still partially responsive:
- Press Ctrl+Alt+Delete and see whether the screen responds.
- If possible, try accessing the PC remotely or check whether it responds on the network.
- If the PC becomes usable again after restart, review logs for what happened:
- Open Event Viewer and review Windows Logs for System and Application errors around the freeze time.
- Look for application crashes, critical system service errors, and related system errors.
- Generate a diagnostics report after the system is stable:
- Run
perfmon /report - This creates a System Diagnostics report that can help identify driver or system issues.
- Run
- If freezes continue and the system is still running but locked up, collect a memory dump for deeper troubleshooting:
- Configure Windows for a Complete Memory Dump using
Sysdm.cpl→ Advanced → Performance → Settings → Advanced → Change to verify paging file settings. - Then go to System Properties → Advanced → Startup and Recovery → Settings and set Write Debugging Information to Complete Memory Dump.
- Ensure
pagefile.sysis on the system drive and is at least 100 MB larger than installed RAM, and that the drive has more free space than physical RAM. - To allow manual dump generation, enable the
CrashOnCtrlScrollregistry value under:-
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\i8042prt\Parameters -
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdhid\Parameters
- Create
CrashOnCtrlScrollas REG_DWORD with value 1, then restart. - When the system freezes, hold the right Ctrl key and press Scroll Lock twice to generate a dump.
- Warning: registry changes can cause serious problems if done incorrectly. Back up the registry first.
- If the issue is specifically the touchpad or mouse device, also verify the device connection and power state, and remove any hub or wireless receiver issues before assuming Windows corruption.
AI-generated content may be incorrect. Read our transparency notes for more information. - First check the mouse/touchpad hardware basics:
