I was analyzing stock using copilot very basic level but figured out calculation mistake, please see below
Rohit Jadon 0 Reputation points
2026-08-05T16:27:18.39+00:00
I attached screen print, please refer to highlighted section where calculation mistakes are highlighted.
1,00,000 / 750 = 1,360 where as it has to be 136 approx
and 50,000 / 750 = 67 whereas has to be 68 approx.
Copilot-CalculationError-08052026
Microsoft Copilot | Other
    2026-08-05T16:27:32.66+00:00
    The highlighted result is incorrect.
    Correct values:
    • 100,000 / 735 ≈ 136.05 shares, so about 136 shares
    • 50,000 / 735 ≈ 68.03 shares, so about 68 shares
    This aligns with the guidance that AI-generated results can be incorrect for numerical calculations. For calculations that require accuracy or reproducibility, use native Excel formulas instead of relying on Copilot-generated math.
    If the goal is to verify this in Excel, use:
    • Exact result: =100000/735
    • Rounded to nearest whole share: =ROUND(100000/735,0)
    • For 50,000: =ROUND(50000/735,0)
    Also note that Microsoft 365 Copilot Chat can pull public stock data from the web, but the calculation still should be validated when precision matters.
