Edge Error 403 Forbidden
Christopher Kobi 0 Reputation points
2026-08-05T13:16:48.08+00:00
I keep getting error 403 when trying to open a particular site through Microsoft Edge and tried all recommended fixes but to no avail. Any other suggestions?
Microsoft Edge | Website issues | Previous Windows versions
  1. Pavle Peković 6,850 Reputation points Volunteer Moderator
    2026-08-05T13:40:41.51+00:00
    That website requires authentication. It identifies "you" like a user who does not have access.
    What you do is to start InPrivate windows, go to that website and check if everything works. If it does, go back to your profile and remove cookies related to that website and try again.
    I don't know what that website requires, or maybe, for example, your IP is blocked.
    Check on some other PC.
