Power Query Editor freezes (Not Responding) for 20 seconds when opening even a trivial 2-row/3-column table
oleg kaz 0 Reputation points
2026-08-04T07:15:10.13+00:00
Product: Microsoft 365 Personal, Excel, Version 2608 Build 20326.20000 (Insider Beta Channel)
Description:
Power Query Editor consistently freezes and displays "Not Responding" for 20-30 seconds every time it opens, even on a brand-new, trivial workbook (3 columns, 2 rows, loaded from a simple range/table). The delay happens on the very first load and also on every subsequent load within the same Excel session — closing the editor and reopening it on the same query produces the same 20-30 second freeze each time.
This is not related to data volume: the same freeze occurs on a 246-row table and on a 2-row test table equally.
Troubleshooting already performed (no change in behavior):
  1. Disabled all COM add-ins (including Adobe Acrobat PDFMaker, xlwings) — no effect
  2. Tested in Excel Safe Mode (excel.exe /safe) — same 20-30 second freeze persists
  3. Set "Always ignore Privacy Level settings" in Power Query privacy options — no effect
  4. Confirmed memory/CPU are not the bottleneck — system has 16GB RAM (AMD Ryzen 5000 series), verified via Task Manager that memory usage is normal (~50-60%) and not the cause
  5. Monitored Task Manager during the freeze: Microsoft.Mashup.Container.Loader.exe shows 0% CPU / near-0 memory (idle, not computing), while EXCEL.EXE itself shows active CPU usage and growing working set during the freeze — indicating the hang is inside the Excel UI thread itself, not an external wait
  6. Disabled Windows Defender real-time protection entirely and retested — no effect
  7. Confirmed "Not Responding" state appears both on the Power Query Editor window and, separately, on the initial "Queries & Connections" pane (~6-7 seconds), though the pane only hangs on first use per session while the Editor hangs every time
  8. Checked and found no "Disable hardware graphics acceleration" option available under Excel Options → Advanced on this build
Expected behavior: Power Query Editor should open near-instantly for a dataset this small, consistent with behavior on other machines/installations.
Actual behavior: 20-30 second freeze with "Not Responding" on every single Power Query Editor open, regardless of data size or session state.
Suspected cause: Given that add-ins, antivirus, and memory have all been ruled out, and the freeze is reproducible even on a brand-new empty workbook, this appears to be either a regression specific to Insider Beta Channel Build 20326.20000, or a corrupted Mashup engine component registration requiring reinstall/repair.
Microsoft 365 Insider | Other
  1. Kai-H 26,385 Reputation points Microsoft External Staff Moderator
    2026-08-04T12:58:27.7733333+00:00
    Hi, oleg kaz
    Since the delay also occurs in Safe Mode with a new workbook, it is unlikely to be caused by the data, add-ins, or antivirus. Build 20326.20000 was released to the Beta Channel on July 29, 2026, but this specific behavior is not listed as a confirmed known issue.
    Here are some suggestions you can try:
    Close all Office applications. Open %LocalAppData%\Microsoft\Office\16.0 and rename the PowerQuery folder to PowerQuery.old, then restart Windows. Excel will recreate the Power Query cache. This has resolved similar cases where the editor froze even with blank workbooks.
    Temporarily leave the Beta Channel and switch to Current Channel. Then open Excel, select File > Account > Update Options > Update Now, and retest. If the delay disappears, that strongly points to a Beta-build regression rather than a damaged workbook.
    If it continues on Current Channel, open Windows Settings > Apps > Installed apps > Microsoft 365 > Modify, then run Online Repair, not Quick Repair. Online Repair replaces the full Office installation and damaged components.
    Finally, submit the issue through Excel > Help > Feedback > Report a Problem, including the build number and the fact that switching channels changes the behavior, if confirmed.
    Thank you for your patience in reading, I hope this information has been helpful to you.
    If the answer is helpful, please click "Yes" and kindly upvote it. If you have extra questions about this answer, please click "Comment."
  2. oleg kaz 0 Reputation points
    2026-08-04T14:30:18.68+00:00
    Disabling Enable background refresh in the Query Properties improved the Power Query editor opening speed to ~5 seconds, but the initial 8-9 second cold-start delay for the 'Queries & Connections' task pane itself persists.
    Severe 8-9 second delay during .NET Framework initialization when opening "Queries & Connections" pane in Excel (Windows 11 Dev Channel)
    Description:Environment:OS: Windows 11 Pro (Dev Channel, latest flight)
    Hardware: High-speed NVMe SSD, modern CPU
    Summary:There is a consistent 8 to 9-second delay/freeze (accompanied by the blue loading spinner and the "Loading .NET Framework" status message at the bottom) when clicking the "Queries & Connections" button under the Data tab in Excel.
    This issue occurs only during the very first (cold) initialization of the pane in an Excel session. Subsequent openings of the pane are instant. However, this delay is highly disruptive and reproduces even on a completely blank, newly created workbook.
    Diagnostic Steps Already Taken (None of these resolved the issue):
    1. Network Disconnected: Disabling Wi-Fi/Internet completely does not change the timing. The delay remains exactly 8-9 seconds, ruling out a network-based CRL (Certificate Revocation List) timeout.
    2. Exploit Protection (SimExec / Child Processes): Configured Exploit Protection overrides for excel.exe (disabling SimExec and Child Process mitigation).
      All Excel COM Add-ins have been disabled, global Power Query caches cleared, and custom XML data inspected/removed. Microsoft .NET Framework Repair Tool was also deployed.
      Office Repair: Performed a full online repair/reinstallation of Microsoft 365.
  3. Deleted
  4. oleg kaz 0 Reputation points
    2026-08-06T07:33:13.9666667+00:00
    I applied this solution, but it had no impact on the Power Query launch speed. Even after disabling "Enable background refresh" and renaming the folder to PowerQuery.old, the opening speed remains exactly the same both with and without background refresh active. Regarding the second suggestion (switching from the Beta/Dev channel to the Current channel) — I prefer not to switch and would like to stay on my current update channel for now.
