"Hardware Error" in reliability problem history while gaming. (Code: a1000005)
nikosmss 20 Reputation points
2026-08-03T21:31:23.72+00:00
So I just got a new GPU and since then I'm getting a ton of Hardware Errors in the reliability monitor while playing games. I've tried older driver versions and a few troubleshooting options but nothing seems to help. Can anyone help?
Specs:
MB: Aorus B450 pro
Ram: 16gb 3600mhz
CPU: Ryzen 5 3600XT
GPU: Gigabyte RX 7600 Gaming OC
SSD: M.2 990 plus
Problem:
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: a1000005
Parameter 1: 0
Parameter 2: 0
Parameter 3: 0
Parameter 4: 0
OS version: 10_0_26200
Service Pack: 0_0
Product: 768_1
OS Version: 10.0.26200.2.0.0.768.101
Locale ID: 1033
sysdata.xml
WERInternalRequest.xml
AMD_WATCHDOG-20260803-2341.txt
Ivan B 123.5K Reputation points Independent Advisor
2026-08-03T22:16:47.0566667+00:00
Hi ,
Search for msinfo32.exe in the search bar, take a screenshot, and post it here so we can see the correct laptop model or desktop configuration.
Access the c:\windows\minidump folder, copy the files to your desktop, then upload them to OneDrive or Google Drive and post the link here for analysis.
0 additional answers
