Copilot Markdown Code Blocks Not Rendering in Microsoft Edge (Works Correctly in Google Chrome)
Stefan Arsić 20 Reputation points
2026-08-03T12:03:28.67+00:00
I'm experiencing an issue in Microsoft Copilot when using Microsoft Edge.
Markdown code blocks are not displayed correctly. Instead of the actual code, I only see gray loading/skeleton placeholders. Regular text renders normally.
The same conversation and the same Microsoft account work correctly in Google Chrome, where code blocks are displayed without issues.
Troubleshooting performed:
  • Disabled hardware acceleration
  • Reset Edge flags
  • Restarted Edge
  • Inspected the page using DevTools
Technical findings:
  • <pre> and <code> elements exist in the DOM
  • Code content is present and accessible via innerText and textContent
  • CSS properties appear normal (display: block, visibility: visible, opacity: 1)
  • Browser console reports:
Cannot find module './src/CodeBlockStrings.json'
Expected behavior: Code blocks should render normally in Microsoft Edge, as they do in Google Chrome.
Actual behavior: Only gray skeleton placeholders are displayed instead of the code content.
  • Reset Edge flags
  • Restarted Edge
Technical findings:
Microsoft Copilot | Windows Copilot | App
Bjørn Tore 80 Reputation points
2026-08-04T09:37:01.3666667+00:00
Check the language settings in both browsers.
Code blocks work in English, but they do not seem to work in other languages.
5 additional answers
  1. Mike Robins 5 Reputation points
    2026-08-12T14:37:55.1466667+00:00
    It's essentially unusable at this point. When will this be fixed?
