To better assist you, could you provide a little more information?
- Is this a personal device or a work/school-managed device?
- Are you being prompted for the BitLocker recovery key at startup?
- When you say "Manage BitLocker" is not opening, do you receive an error message, or does nothing happen?
In the meantime, you can try the following:
- If it's your personal device, check whether your recovery key is stored in your Microsoft account:
If it's a work or school device, contact your IT administrator. The recovery key may be stored in Microsoft Entra ID (Azure AD) or Active Directory.
- If Windows still starts normally but the BitLocker management console won't open, you can check BitLocker status from an elevated Command Prompt by running:
- manage-bde -status
If you're locked out of the device and don't have the BitLocker recovery key, Microsoft cannot recover or bypass it. The recovery key is required to unlock the drive.
Please "Accept the Answer" if this information helped you. This will help us and others in the community as well.
