how to fix my power point
Ayo Ade 0 Reputation points
2026-08-03T08:37:59.9066667+00:00
my power point is not loading and not coming up, stopped working and not responding on my system..#repairs
Microsoft 365 and Office | PowerPoint | Other | Windows
  1. DYARI BARHAM 37,656 Reputation points Independent Advisor
    2026-08-03T09:23:22.0833333+00:00
    Hi ,
    I'm Dyari. Thanks for reaching out.
    Press Ctrl + Shift + Esc to open Task Manager > Processes tab > Find any running PowerPoint tasks > End Task.
    Click Start > Type Run and hit enter > Type powerpnt /safe and hit enter to launch without add-ins > If it opens normally, disable faulty add-ins under File > Options > Add-ins.
    If it does not help, open your system Settings > Apps > Installed apps > Search for 365 or Microsoft Office > Click the three dots > Modify > Online Repair.
