Hi, I have an issue with EdgeUpdater crashes.
Miloslava Harcová 0 Reputation points
2026-08-02T06:56:41.64+00:00
This started on the 20. 7. 2026. It was after a windows update I think? My event viewer is being absolutely spammed with updater crashes.User's image All of the red x are just microsoft edge update crashing. In event viewer the error code is always : 0xc0000409, the faulting module msedgeupdate.dll. I have tried going to apps and repairing from there and I have also tried downloading the installer and re-installing edge. Nothing works. I do NOT USE edge, but this constant error spam is bothering me and I also started experiencing some weird crashes alongside this? I do not know if they are related but they seem to coincide with the updater re-trying....
Is there any way I can try to fix this? I am at loss, no amount of googling will tell me a solution (I already tried reinstalling it and that is the only thing that the help suggests).
Microsoft Edge | Install and update | Windows 11
2026-08-07T07:41:07.44+00:00
Hello, I contacted actual microsoft support and managed to find a solution. Writing it here in case anybody needs it:
The man had me end the tasks connected to edgeupdate through cmd. Afterwards he had me rename the file edgeupdate in programfiles(x86)/microsoft to edgeupdate.old. Afterwards he had me download the edgeinstaller from the official website and reinstall it. This fixed the issue as it created an entire new update folder, whereas my previous attempts were apparently just using the corrupted folder.
5 additional answers
  1. Alex-L 12,565 Reputation points Microsoft External Staff Moderator
    2026-08-06T14:17:51.6233333+00:00
    Hi Miloslava Harcová
    At this point the results are actually very useful:
    • Both Edge Update services are stopped
    • Edge Update scheduled tasks are disabled
    • SFC found no corruption
    • DISM completed successfully
    • Yet MicrosoftEdgeUpdate.exe is still being launched and crashing
    That suggests something else on the system is calling MicrosoftEdgeUpdate.exe directly rather than the normal Edge update services/tasks.
    The most suspicious detail is the version mismatch shown in Event Viewer:
    • MicrosoftEdgeUpdate.exe 1.3.225.7
    • msedgeupdate.dll 1.3.249.3
    Those components normally come from the same Edge Update installation. A mismatch can indicate a partially updated or corrupted Edge Update component.
    My next step would be to use Autoruns (Microsoft Sysinternals) and search for:
    • EdgeUpdate
    • msedgeupdate
    to see what is launching it after startup.
    If Autoruns shows nothing unusual, I would try completely removing the Microsoft Edge Update component and then reinstalling the latest Edge package, as the evidence is increasingly pointing to a corrupted Edge Update installation rather than a Windows system file problem.
