Upgrade from build 29617 to 29639 fails with 0x80070005 - 0x200A
Jan Nelken 55 Reputation points
2026-08-01T07:23:07.64+00:00
ISO Upgrade in place (with internet access off and selecting no updates during install) fails:
Since on August 13 build 29617 will loose its certificate - how to upgrade?
All published diagnostics steps were carried on - no effect.
CrazyKats 19,585 Reputation points Volunteer Moderator
2026-08-02T18:38:44.1766667+00:00
If you want to Accept one of Bryce's answers
click the 3 dots at the bottom of his Answer
and click Accept as Answer.
Build 26300 is a Dev build. At this point I would stay
on that build and avoid Canary until more bugs
are worked out.
BryceSor 5,500 Reputation points Volunteer Moderator
2026-08-01T08:19:34.59+00:00
Hi Jan Nelken,
Check this link as it may help you too https://learn.microsoft.com/en-us/answers/questions/5963250/im-staying-on-29617
2 additional answers
  1. Jan Nelken 55 Reputation points
    2026-08-01T08:40:12.1233333+00:00
    1. I retried first step again; are these results expected or suspicious?
    a) icacls "%windir%\WinSxS" /reset /t /c /q
    C:\WINDOWS\WinSxS\x86_wpf-presentationhostexe_31bf3856ad364e35_10.0.29617.1000_none_42f9c8f5b38bcc70\PresentationHost.exe: Access is denied.
    C:\WINDOWS\WinSxS\x86_wpf-presentationhostproxy_31bf3856ad364e35_10.0.29617.1000_none_fd90ac510d3d0ba2\PresentationHostProxy.dll: Access is denied.
    **Successfully processed 110 files; Failed processing 71031 files
    **b) icacls "%windir%\SoftwareDistribution" /reset /t /c /q
    C:\WINDOWS\SoftwareDistribution\Download\ba77ac7506c29b7c\Microsoft-Windows-Wifi-Client-Qualcomm-Qcamain10x64-FOD-Packageamd6410.0.29639.1000\amd64_dual_netathr10x.inf_31bf3856ad364e35_10.0.29639.1000_none_d97936c456d57c0e\le_ctl_ar6320_3p0_nfa344a_hightx_m.bin: The system cannot find the path specified.
    **Successfully processed 51538 files; Failed processing 6614 files
    **C:>icacls c:\Windows
    c:\Windows NT SERVICE\TrustedInstaller:(CI)(F)
           NT AUTHORITY\SYSTEM:(M)
           NT AUTHORITY\SYSTEM:(OI)(CI)(IO)(F)
           BUILTIN\Administrators:(M)
           BUILTIN\Administrators:(OI)(CI)(IO)(F)
           BUILTIN\Users:(OI)(CI)(RX)
           CREATOR OWNER:(OI)(CI)(IO)(F)
           APPLICATION PACKAGE AUTHORITY\ALL APPLICATION PACKAGES:(OI)(CI)(RX)
           APPLICATION PACKAGE AUTHORITY\ALL RESTRICTED APPLICATION PACKAGES:(OI)(CI)(RX)
    Successfully processed 1 files; Failed processing 0 files
  2. Jan Nelken 55 Reputation points
    2026-08-02T18:32:14.0633333+00:00
    I re-installed Windows 11 from a CD; went back to an old build - then I run Windows Update - I ended up on build 26300 without any problems - now Windows update does not show any newer updates :-)
    Thank you for staying with me on this odyssey - I don't know how to mark your assistance as 'Accepted' - but still I am grateful for your help.
