Azure Virtual Desktop Hybrid extension fails with InvalidTemplate on Arc-enabled Firestorm2
Prince Amor 0 Reputation points
2026-08-01T04:07:35.7433333+00:00
I am trying to deploy Azure Virtual Desktop Hybrid to an Azure Arc-enabled on-premises VM.
Arc machine:
Firestorm2
Resource group:
Robocamp
Host pool:
VDI-Hybrid-GPU
Subscription:
2d1e3e16-e035-4b32-8b70-2ea1a6ce117d
Machine status:
  • Azure Arc Agent Status: Connected
  • AzureAdJoined: YES
  • AzureAdPrt: YES
  • HostNameUpdated: SUCCESS
  • Device Name: Firestorm2
  • GPU-P is working and NVIDIA RTX 4500 Ada is visible inside the VM
The Azure Virtual Desktop Hybrid extension deployment fails before the extension reaches the machine.
Failed deployment:
Firestorm2-SHProxy
Error:
DeploymentFailed / InvalidTemplate
Exact error:
Deployment template validation failed:
"The template resource '[concat(parameters('vmName'), '/AzureVirtualDesktop')]' at line '1' and column '2338' is not valid. The type property cannot be an expression."
No local extension logs are created under:
C:\ProgramData\GuestConfig\extension_logs\Microsoft.AzureVirtualDesktop.CloudDeviceExtension
This appears to fail during Azure ARM template validation before guest extension execution.
A Microsoft desktop and app virtualization service that runs on Azure. Previously known as Windows Virtual Desktop.
  1. Rakesh Agrawal 5 Reputation points
    2026-08-11T15:07:18.34+00:00
    Root Cause Analysis
    The error DeploymentFailed / InvalidTemplate occurs because the ARM template or Bicep module initiating the extension deployment evaluates the type field using a template function/expression (e.g., [parameters('extensionType')] or [concat(...)]). ARM template engine rules strictly forbid expressions in the resource type field.
    Because template validation fails at the Azure Resource Manager (ARM) plane, the deployment aborts before generating a API payload to the guest, explaining why no local execution logs exist under C:\ProgramData\GuestConfig\extension_logs\.
    Resolution Steps
    Hardcode the Resource Type in the Template Ensure the type property in your deployment template is hardcoded as a literal string rather than an expression.
    For Azure Arc-enabled Servers (Hybrid/On-Premises):
    JSON
       "type"
      __For Standard Azure VMs:__
      JSON
      ```yaml
      "type"
      __Fix Resource Naming & Parent Structure__ Separate the parent machine name from the extension name instead of dynamically concatenating them inside `type`:
      JSON
      ```json
    1. Deploy via Direct Az CLI / PowerShell Workaround If deploying through the Azure Portal UI or a pre-packaged template triggers this, bypass ARM template processing by issuing a direct Arc extension CLI command: Code snippet
         az connectedmachine extension create \
    --resource-group "Robocamp"
    --machine-name "Firestorm2"
    --name "AzureVirtualDesktop"
    --publisher "Microsoft.AzureVirtualDesktop"
    --type "CloudDeviceExtension"
    --location "<your-region>"
