What could be the problem?
Oladele, Oluwatomiwa 0 Reputation points
2026-07-31T17:10:17.7766667+00:00
Logs blade in sentinel showing connection to server error. KQL queries can't retrieve data because of said error
Microsoft Security | Microsoft Sentinel
    2026-07-31T17:10:33.1166667+00:00
    Common causes for Microsoft Sentinel Logs/KQL failures in this scenario are:
    1. Wrong workspace selected
      KQL queries can fail if the correct workspace was not selected before running the query.
    2. Missing access or permissions
      If the user does not have the required permissions, queries can return errors such as:
      • Table could not be found or is empty
      • 401-Unauthorized
    3. Referenced table or workspace does not exist or has no data
      If the table is missing, empty, or inaccessible, KQL cannot return results.
    4. Invalid workspace ID or inaccessible workspace scope
      An invalid workspace ID can cause errors such as:
      Client does not have access to any workspaces or client provided invalid workspace(s) in the scope.
    5. Authentication token issue
      If the authentication token is invalid or expired, KQL queries can fail with 401-Unauthorized. Reauthentication is the documented action.
    6. Backend service issue
      If the error is Cannot access a disposed object, that indicates an internal backend service error. The documented action is to retry, and open a support ticket if it persists.
    7. Query design issue causing timeout
      If the query has no time filter or is too broad, it can time out at the gateway. Add a time range and extra filters.
    8. Malformed or unsupported KQL
      Queries fail if they reference invalid columns/tables, use unsupported functions such as ingestion_time(), or use unsupported control commands.
    A practical check order is:
    1. Verify the correct workspace is selected in Sentinel.
    2. Confirm the tables being queried actually exist and contain data.
    3. Check that the account has access to the workspace and tables.
    4. Reauthenticate if the error mentions 401-Unauthorized.
    5. Add a time filter to the query to avoid timeout issues.
    6. Remove unsupported functions such as ingestion_time() and avoid control commands.
    7. If the error is Cannot access a disposed object, retry and open a support ticket if it continues.
    If the exact error text from the Logs blade is available, it can usually be mapped directly to one of the documented KQL error conditions above.
