HOW TO FIX UNREADABLE TOOLBAR/ RIBBON ETC
Les Wilson 20 Reputation points
2026-07-31T14:05:32.88+00:00
These are all far too small to read. How do I fix it
Windows for home | Windows 11 | Display and graphics
DaveM121 932.3K Reputation points Independent Advisor
2026-07-31T14:45:18.2666667+00:00
1
If this problem is only in the Office apps like Word, there is only one setting available in Word that may help
Try using the method provided in this link to switch from Mouse to Touch controls in Word.
That should make the ribbon controls bigger.
https://support.microsoft.com/en-us/word/turn-touch-mode-on-or-off
2
If that does not resolve the problem, the only option would be to increase the Scale percentage on your screen, but this change will make everything on your screen larger.
Right click your Desktop and select Display Settings.
In there, you can increase the Scale percentage on oyur screen.
0 additional answers
