Managing media playback issues and settings in Microsoft Edge on Windows 11
please help me to access the sound or volume this laptop,idont know how to fix it
Hi! Let me help you.
Please hover your mouse over the sound icon in the lower-right corner, then right-click it and select Troubleshoot Sound. Let the troubleshooter finish its task, then this should either resolve the problem or display an error message.
If that doesn't work, we need to remove the Audio driver from the Device Manager and restart the PC to reinstall it.
Here are the steps to completely remove a Device from your computer.
Step 1. Use the Windows key + X shortcut.
Step 2. Select Device Manager.
Step 3. Expand the entry Sound, Video, and Game Controllers. Right-click the problematic device, which is either Realtek Audio, or AMD High-definition Audio, or High-Definition Audio, depending on the audio device installed in your PC, and select Uninstall device.
Step 4. You need to check the option Delete the driver software for this device and then click the Uninstall button.
Step 5. Reboot the computer.
After the reboot, please see if the problem is fixed.
If that still does not work, please visit the support website of your laptop or desktop and then download and install the latest Audio driver, then restart the PC.
If you can't access the sound or volume on your laptop, try these basic steps:
If the issue persists, please share your laptop model and Windows version, along with any error messages or screenshots, so the community can provide more specific guidance.
