How to fix livekernelevent 141 problem?
Juvaney Tarek 20 Reputation points
2026-07-29T20:23:08.7933333+00:00
I've tried multiple solutions that i found on the internet and the problem still procced, screen freezes into a black screen and had to force restart the pc this happen on random times playing games , watching Youtube etc
My pc is entirely new and the specs are
Mother board : H610M K DDR4
CPU : intel core i5 12400f TRAY
GPU : Nvidia Geforce RTX 5060 8gb
PSU : COUGAR ATLS 750W 80PLUS BRONZE
This is the code of the problem
Source
Windows
Summary
Hardware error
Date
‎7/‎29/‎2026 2:41 PM
Status
Not reported
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 141
Parameter 1: ffffdd87b78ee460
Parameter 2: fffff80690d07ef0
Parameter 3: 0
Parameter 4: 0
OS version: 10_0_22631
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.22631.2.0.0.256.48
Locale ID: 1033
Thanks.
Lester Bernard Reyes 84,820 Reputation points Independent Advisor
2026-07-30T00:15:38.9766667+00:00
Hi, I'm Bernard. I'm happy to help!
Based on the log description, the hardware caused Windows to stop working correctly. Moreover, can you please check the System logs on the PC so I can further examine the root cause of the issue?
To share the System logs, please follow the steps in the link below:
Press the Windows key + X, then select "Event Viewer"
Click the drop-down of "Windows logs"
Right-click System > click Filter Current logs > Check: Critical, Warning, and Error > Hit OK
On the right pane, click "Save Filtered Log File As..."
Save the System logs file to your desktop and share it by following the steps from the link:
https://support.microsoft.com/en-us/office/share-onedrive-files-and-folders-9fcc2f7d-de0c-4cec-93b0-a82024800c07
Note: You can also use your preferred cloud storage to upload and share the logs.
1 additional answer
  1. Lester Bernard Reyes 84,820 Reputation points Independent Advisor
    2026-07-30T17:12:50.2466667+00:00
    Hi, thank you for updating and providing the steps. I am glad it is now all good.
