Solution for 'class not registered ' message
John Hodgson 0 Reputation points
2026-07-28T17:31:01.9866667+00:00
Can no longer access Settings and other apps. Keep getting the message: "Class not registered". How can I download and install; or repair windows 11? Have tried many suggested solutions.
Microsoft Teams | Microsoft Teams Free | Other
  1. Lester Bernard Reyes 84,710 Reputation points Independent Advisor
    2026-08-07T12:08:55.7166667+00:00
    Hi, thank you for replying. In this case, I recommend creating a new user admin and check, kindly follow the steps below:
    Go to Settings > Accounts > Other users > Add account
    Follow the prompts to create an account.
    Then go to Settings > Accounts > Other users > Select the account you created > Click "Change account type" then select "Administrator"
    Restart the PC and log in to the new account
    For reference: https://support.microsoft.com/en-us/windows/manage-user-accounts-in-windows-104dc19f-6430-4b49-6a2b-e4dbd1dcdf32
  2. Lester Bernard Reyes 84,710 Reputation points Independent Advisor
    2026-07-28T18:05:23.1233333+00:00
    Hi, I'm Bernard. I'm happy to help!
    To repair Windows 11, I suggest doing an in-place upgrade, which will upgrade the device to the latest version and repair all issues without deleting any files.
    Go to the Windows 11 website: https://www.microsoft.com/en-us/software-download/windows11
    Under Download Windows 11 Disk Image (ISO), select Windows 11 (multi-edition ISO)
    1.    Once done downloading the ISO, kindly right-click on the ISO, then click Mount>click Setup.exe
    2.    You may be prompted by User Account Control. Click on Yes if so
    3.    In the Install Windows 11 dialog, click Next
    4.    Setup will check your PC and show a license agreement. Click on Accept in the license terms dialog.
    5.    Wait for the setup program to check for the available free space.
    6.    On the Ready to install page, make sure Keep personal files and apps has been checked.
    7.    Then click Install and just follow the prompt.
    8.    Windows 11 will restart your device several times and lead you to the lock screen. Depending on the options you set, it will keep all your files, apps, and user accounts.
