Purview Data Quality
Abhradeep Das 0 Reputation points
2026-07-28T11:43:56.0933333+00:00
Hi Team,
We are using Microsoft Purview and noticed that AWS Redshift is available as a supported data source for metadata scanning and cataloging in Data Map.
However, when configuring Data Quality, we do not see an option to add AWS Redshift as a data source.
Could you please clarify the following:
  1. Is Amazon Redshift currently supported as a data source for Microsoft Purview Data Quality?
  2. 1
  3. If it is not currently supported, are there any recommended workarounds or alternative approaches to perform data quality assessments on data stored in Amazon Redshift?
  4. Are there any roadmap plans to add native Amazon Redshift support to the Data Quality capability in Purview?
Our understanding is that Redshift can be scanned and cataloged successfully in the Data Map, but we are unable to find a corresponding option while configuring Data Quality.
Any guidance or official documentation would be greatly appreciated.
Thank you.
Microsoft Security | Microsoft Purview
    2026-07-28T11:44:16.9633333+00:00
    Amazon Redshift is currently supported in Microsoft Purview for Data Map metadata scanning and cataloging, but it is not listed as a supported data source for Data Quality.
    Supported Data Quality sources currently include Azure Data Lake Storage Gen2, Azure Databricks Unity Catalog, Azure Synapse serverless, Azure Synapse Data Warehouse, Azure SQL Database, Azure SQL Managed Instance, Azure Dedicated SQL Pool, Google BigQuery, Snowflake, Fabric, Amazon S3, Dataverse, Google Cloud Storage, Oracle, and SQL Server. Amazon Redshift does not appear in that supported Data Quality source list.
    For the current gap:
    1. Catalog Redshift in Data Map
      • Redshift can be registered and scanned in Data Map.
      • Purview supports extracting metadata such as databases, schemas, tables, views, stored procedures, and functions.
    2. Use an alternative supported Data Quality source
      • If Redshift data can be made available through a supported source for Data Quality, that supported source can be assessed there instead.
      • Examples of supported Data Quality sources include Snowflake, Google BigQuery, Azure SQL, Synapse, Fabric, and Amazon S3.
    3. No documented native Redshift Data Quality support or roadmap in the available documentation
      • There is no published support statement in the available documentation showing Amazon Redshift as a native Data Quality source.
      • There is also no roadmap statement in the available documentation confirming when or whether native Redshift support will be added.
    So the current behavior is consistent with the product documentation: Redshift is supported for scanning in Data Map, but not currently supported as a Data Quality data source in Purview Unified Catalog.
