Orphaned PowerPlatformSAL blocking VNet/Subnet deletion
Jeffery Scully 0 Reputation points
2026-07-27T21:32:51.49+00:00
Resource ID: /subscriptions/cdaf5f68-c7f4-4cd1-aab8-9483328f3b77/resourceGroups/lakebrook-eu-poc/providers/Microsoft.Network/virtualNetworks/sql-mirror-eu-vnet/subnets/gateway-subnet/serviceAssociationLinks/PowerPlatformSAL
Error: UnauthorizedClientApplication for App ID b677c290-cf4b-4a8e-a60e-91ba650a4abe
Azure Virtual Network
An Azure networking service that is used to provision private networks and optionally to connect to on-premises datacenters.
  1. Arun Vijayakumar 0 Reputation points
    2026-07-27T23:23:34.37+00:00
    Hi @Jeffery Scully
    PowerPlatformSAL is a Service Association Link (SAL) on the subnet. Azure does not allow a subnet or its parent VNet to be deleted while a service association link is present. The related Power Platform resource or VNet integration must be removed first.
    Please first confirm that the Power Platform VNet data gateway, Power BI/Power Platform network integration, and any other resource that used this subnet have been deleted or disconnected. Also check whether the subnet still has a delegation or any remaining IP configurations:
    az network vnet subnet show \
    --subscription cdaf5f68-c7f4-4cd1-aab8-9483328f3b77 \
    --resource-group lakebrook-eu-poc \
    --vnet-name sql-mirror-eu-vnet \
    --name gateway-subnet \
    --query "{delegations:delegations,serviceAssociationLinks:serviceAssociationLinks,ipConfigurations:ipConfigurations}" \
    --output json
    If a Power Platform VNet data gateway is still associated with the subnet, remove the gateway association first. If the gateway was deleted but the PowerPlatformSAL persists, you can also consider creating a new VNet data gateway on the same subnet and then deleting it, which can cause the service to detect and remove a stale SAL.
    If the SAL remains after all dependent resources are removed, do not attempt to force-delete it. Open an Azure Support request under Azure Virtual Network/Networking or Power Platform, and explicitly request backend removal of the orphaned PowerPlatformSAL. Include the full SAL resource ID, the UnauthorizedClientApplication error, the subscription/resource group/VNet/subnet details, the output of the command above, and the date on which the linked Power Platform resource was removed.
    Arun
