how do i use AKS?
Will Chen 20 Reputation points Microsoft Employee
2026-07-27T01:25:36.9766667+00:00
how do i use AKS? and i know nothing about kubernetes - and i want to use windows instead of linux
Azure Red Hat OpenShift
An Azure service that provides a flexible, self-service deployment of fully managed OpenShift clusters.
Marcin Policht 107.2K Reputation points MVP Volunteer Moderator
2026-07-27T03:30:44.3833333+00:00
To deploy, simply follow https://learn.microsoft.com/en-us/azure/aks/learn/quick-kubernetes-deploy-portal?tabs=azure-cli
In step 5, instead of Ubuntu Linux, select Windows
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
0 additional answers
