Launching Microsoft Edge on Windows 11
Hello J K,
Could you share a screenshot of the complete Connection Error message, and confirm:
These appear to be two possible issues, so this will help identify whether the problem is with Edge, Microsoft Store, or the HP download. Please hide any personal information in the screenshot.
Hi J K,
It sounds like there might be two separate issues here: Edge showing a connection error, and the HP Smart app not downloading. I’ll outline a few checks to help narrow down what’s going on. To start, could you please confirm a couple of details:
In the meantime, a few quick checks you can try:
Test another browser (if available): If you have Chrome/Firefox installed, see if websites open there. This helps confirm if the issue is only with Edge.
Clear Edge cache:
3. Select 'Settings' from the menu that appears.
5. Scroll down to the 'Clear browsing data' section and click 'Choose what to clear.'
6. In the new window, make sure 'Cached images and files' is checked. You can also select a time range from the drop-down menu (for example, 'All time' is most thorough).
You should see a message confirming that your selected data has been cleared. After this, try visiting the website again to see if the problem is resolved.
Once you can share which sites are affected and how you're trying to get HP Smart, it'll be easier to see whether the issue is with Edge itself, the Store, or the HP link. If the steps above do not resolve the problem, please let me know any additional details or error messages you see.
Stuart
