How to use COUNTIFS with case sensitive criteria
Mike H 61 Reputation points
2026-07-25T20:39:55.87+00:00
I'm trying to use COUNTIFS function where the criteria is upper and lower case characters. However the COUNTIFS result counts both upper and lower characters. That is two "b" instead of one "b" and one "B".
countifs
EmilyS726 267.4K Reputation points Independent Advisor
2026-07-25T21:18:10.9+00:00
For your C2 cell, use this instead. COUNTIF and COUNTIFS are not case-sensitive.
=SUMPRODUCT(--EXACT(Dtype,C$1))
OR
=SUMPRODUCT(--EXACT($A:$A,C$1))
3 additional answers
  1. Mike H 61 Reputation points
    2026-07-30T21:20:59.4133333+00:00
    Still investigating.
  2. Ashish Mathur 102.4K Reputation points Volunteer Moderator
    2026-07-30T23:05:09.5166667+00:00
    In cell C2, enter this formula
    =BYCOL(C1:G1,LAMBDA(c,SUM(1*(REGEXTEST($A$2:$A$6,c)))))
    Hope this helps.
  3. IlirU 2,651 Reputation points Volunteer Moderator
    2026-07-31T07:22:19.2333333+00:00
    Use this formula in cell C2:
    =BYCOL(C1:G1, LAMBDA(a, SUM(--EXACT(A2:A6, a))))
    or this formula and drag it right:
    =SUM(--EXACT($A$2:$A$6, C1))
    HTH
    IlirU
