how to fix the repair error on my MS access
John Gicheru 0 Reputation points
2026-07-25T07:54:11.94+00:00
whenever I open my MS Access database there is a tab that says repair and nothing happens when I press the button nothing happens the error still appears what should I do?
Microsoft 365 and Office | Access | For home | Windows
  1. Senthil kumar 2,420 Reputation points
    2026-07-25T08:34:32.1233333+00:00
    Hi @John Gicheru
    • First take copy of your database then test the below solution.
    database already opened : Go to the Database Tools tab on the ribbon → click Compact and Repair Database. Access closes the database, repairs it, and reopens it.
    Without opening the database first (better if the file is corrupt and won't open normally):
    • Open Access to the start screen (don't open the broken file)
    • Go to Database Tools tab → Compact and Repair Database
    • In the dialog, browse to and select the corrupt file, then choose a name/location for the repaired copy
    set auto repair
    Set it to run automatically: File → Options → Current Database → check Compact on Close.
    Thanks.
  2. Karl Donaubauer 3,661 Reputation points MVP
    2026-07-25T17:57:28.9833333+00:00
    Senthil Kumar already wrote how to use the built-in repair functionality. The most important thing before you do this, is to create a backup copy of your database file, because sometimes Compact & Repair can make things worse.
    If C&R doesn't help:
    I've seen a lot in Access but never a "tab that says repair". Can you post a screenshot of what you see?
    Servus
    Karl
    Access Forever, News, DevCon
    Access-Entwickler-Konferenz AEK
