Copy and paste a sequence from one project to another in Clipchamps
jacky Perpète 216 Reputation points
2026-07-25T07:38:03.5533333+00:00
I currently have two separate projects created with ClipChamp.
I would like to copy a sequence from my first project to my second project.
This is not currently possible.
The only workaround I have so far is to duplicate the first project, delete the unnecessary sequences, and then export it.
Then, I have to import the exported file into the second project.
This solution works, but it's very cumbersome.
Could it be possible to add a copy and paste function for a sequence from the timeline or an element from 'Your Media' in the future to make things easier for the user?
Thank you.
Microsoft 365 and Office | Clipchamp | Other
  1. Chloe-V 12,610 Reputation points Microsoft External Staff Moderator
    2026-07-26T01:18:36.82+00:00
    Hi jacky Perpète,
    I understand that duplicating the entire project, deleting the unnecessary content, and then exporting and importing the required sequence into another project can be cumbersome.
    Currently, Clipchamp supports copying and pasting one or multiple items within the timeline of the same project. However, copying a timeline sequence or an item from Your Media directly from one project to another has not been mentioned.
    For now, you can continue using the workaround of exporting the required sequence and importing the exported video into the second project. Alternatively, you can duplicate the entire project and edit the copy, although this does not merge the content into an existing project.
    This would certainly be a useful feature. I recommend submitting or voting for this suggestion through the Clipchamp Feedback Portal, where it can be reviewed by the Clipchamp product team.
    Please note that this is a user-to-user support forum. Moderators, contributors including external Microsoft employees cannot directly intervene in Microsoft product features or access back-end systems. Our role is limited to providing technical guidance on reported issues, requests, or ideas only.
    Thank you for your understanding.
