ASR Site Recovery Jobs
GerryNicol 21 Reputation points
2026-07-24T13:09:42.8566667+00:00
For a single server in ASR I am getting repeated Site recovery jobs running as follows
  • Update network settings on the primary virtual machine
  • Processing virtual machine migration
Is there an easy way to stop these jobs from running?
Azure Site Recovery
Azure Site Recovery
An Azure native disaster recovery service. Previously known as Microsoft Azure Hyper-V Recovery Manager.
  1. Christos Panagiotidis 3,551 Reputation points
    2026-07-24T16:14:52.73+00:00
    The repeated “Update network settings” and “Processing migration” entries appear to be Azure Site Recovery control-plane jobs associated with protected-item maintenance or migration state. Their exact purpose cannot be confirmed from the job names alone. Open each job and compare the protected item, operation ID, start time, duration, result, and error details, then review the replicated item’s health and recent events. There is no safe supported way to cancel recurring maintenance while keeping protection intact. If replication is still required and the jobs succeed, leave protection enabled and investigate only warnings, failures, or replication-health degradation. If the migration or protection is no longer required, use the normal Disable replication or Remove protected item workflow and verify cleanup completes. Do not use force deletion merely to suppress jobs; it can purge configuration without completing ordinary cleanup. If successful jobs continue unexpectedly, send their operation IDs and vault diagnostics to Microsoft support.
