A family of Microsoft word processing software products for creating web, email, and print documents.
You can make Word documents much more accessible by adding Alt Text to non-text elements such as pictures, diagrams, charts, and SmartArt. Screen readers will announce this description when they encounter the object.
For Microsoft Word, you can:
- Right-click the image, chart, diagram, or other object.
- Select View Alt Text (or Edit Alt Text, depending on your version).
- Enter a concise but meaningful description of the content and its purpose.
You can also run the Accessibility Checker to identify content that may not be accessible:
- Review > Check Accessibility
Microsoft also provides detailed guidance here:
- Accessibility Checker: Improve accessibility with the Accessibility Checker | Microsft Support
- Add alternative text to shapes, pictures, charts, SmartArt graphics, or other objects: Add alternative text to a shape, picture, chart, SmartArt graphic, or other object | Microsoft Support
Regarding equations and symbols such as “implies” (⇒), Word itself does not control how every mathematical symbol is spoken. The spoken output depends on the screen reader and how the equation was created. If the equation was inserted using Word’s built-in Equation editor, it is generally more accessible than using manually inserted symbols.
Could you let me know:
- Which screen reader are you using (for example, Narrator, VoiceOver, JAWS, or NVDA)?
- Was the “implies” symbol entered using Insert > Equation, or was it inserted as a Unicode/special character?
That information will help determine whether the behavior is expected or whether there is a more accessible way to represent the symbol.
