Microsoft Learn Labs are permanently stuck on "Loading lab..." across multiple browsers, networks, and Microsoft accounts – Possible backend provisioning/API issue
Abdul Rehman 95 Reputation points
2026-07-24T09:22:08.7533333+00:00
Hello Microsoft Learn Support Team,
I am creating this new question because the issue is still unresolved after performing every troubleshooting step that was previously recommended.
First of all, thank you to @Yehor Diriavka and @Chirag Kolte for taking the time to review my previous question and suggesting troubleshooting steps. I carefully followed all of the recommendations, but unfortunately the problem still persists exactly the same.
Problem Description
Whenever I launch any Microsoft Learn lab, the lab never starts successfully.
Instead, it remains on the "Loading lab..." screen indefinitely.
The virtual machine is never provisioned, and the lab environment never becomes available.
This is happening with every Microsoft Learn lab, not just a specific module.
Because of this issue, I am unable to complete the hands-on exercises for my Microsoft Learn training.
Browser Console Errors
While the lab is stuck loading, I opened the browser Developer Tools (F12) and consistently observed errors similar to:
  • API consumer not enabled
  • ArkoseLabs postMessage target origin mismatch
The "API consumer not enabled" message appears repeatedly while the lab is attempting to load.
Since this occurs every time, I suspect the lab provisioning request is failing before the virtual machine is created.
Troubleshooting Already Performed
To make sure the problem was not caused by my own computer or browser, I tested extensively.
Browsers Tested
  • Google Chrome (Latest Version)
  • Microsoft Edge
  • Incognito Mode
  • InPrivate Mode
The issue occurs in every browser.
Browser Cache
I completely cleared:
  • Cache
  • Cookies
  • Site Data
No improvement.
Networks Tested
I tested using multiple internet connections.
  • Home Internet
  • Mobile Hotspot
The exact same issue occurs on both.
Microsoft Accounts Tested
To rule out an account-specific problem, I also tested with multiple Microsoft accounts.
  • My original Microsoft account
  • A completely different Microsoft account
Both accounts experience exactly the same issue.
Different Learn Labs
I also tried launching multiple Microsoft Learn labs.
Every lab remains stuck on:
Loading lab...
Therefore, the issue is not limited to one particular course or lab.
System Information
Operating System:
Windows 10
Browsers:
Google Chrome (Latest)
Microsoft Edge (Latest)
Country:
Pakistan
Microsoft Learn Profile:
https://learn.microsoft.com/en-us/users/abdulrehman-6385/
My Analysis
Since the issue occurs:
  • across multiple browsers,
  • across multiple Microsoft accounts,
  • across multiple internet connections,
  • across different Microsoft Learn labs,
I no longer believe this is caused by:
  • browser cache,
  • cookies,
  • extensions,
  • local network,
  • my computer,
  • or my Microsoft account.
The repeated "API consumer not enabled" error makes me suspect there may be a backend provisioning issue, an API configuration issue, or a Microsoft Learn Lab service issue preventing the lab environment from being created successfully.
The ArkoseLabs message may simply be a secondary warning, but the API-related error appears much more significant.
Request
Could someone from the Microsoft Learn engineering team please investigate whether:
  • there is a provisioning issue affecting my Learn profile,
  • there is an issue with the Learn Lab backend service,
  • there is an API configuration problem,
  • or whether there is a known service outage affecting lab provisioning?
If additional information is required, I will gladly provide:
  • HAR file
  • Browser console logs
  • Correlation ID (if available)
  • Screenshots
  • Any additional diagnostic information
Additional Information
Because I am currently preparing for the Microsoft PL-300 certification, I have continued practicing using the official GitHub lab files in Power BI Desktop.
However, I am still unable to access the Microsoft Learn hosted lab environment, so I would greatly appreciate any assistance in resolving this issue.
Thank you very much for your time and support. I look forward to your guidance.
Nathan Roberts (SN) 13,616 Reputation points Student Ambassador Volunteer Moderator
2026-07-30T17:33:32.5566667+00:00
Hey there, Abdul Rehman & all
I have asked about this, and have a response from our community manager. I have been told that this would fall under credential support here: https://aka.ms/Credentials-Support
You can find support options under the Microsoft applied skills credentials and assessment labs here: https://learn.microsoft.com/en-us/credentials/support/help
You can also report feedback directly through the module, by clicking onto report an issue, which I know you have done. However, this is the only way to report feedback by that team without going to credential support.
I would recommend opening a support request through that team and see if they are able to help.
Hope this helps,
Nathan
2 additional answers
    2026-07-24T09:22:38.99+00:00
    Since the issue persists across browsers, private modes, networks, accounts, and multiple labs, the next supported step is escalation rather than more local troubleshooting.
    For Microsoft Learn lab and Azure Lab Services issues, collect the following and include it in a support request:
    1. Lab plan ID
      In the Azure portal, select the lab plan and open Properties.
    2. Lab ID
      In the Azure portal, select the lab and open Properties. Alternatively, use the lab URL from the Azure Lab Services website.
    3. Approximate time the issue occurred
    4. Errors from the Azure activity log
      In the Azure portal, open the lab plan or lab, then go to Activity log.
    If available, also attach the browser console logs, HAR file, screenshots, and any correlation details, since the problem appears consistent and reproducible.
    A few supported checks remain relevant:
    • If the lab uses Cloud Shell, enable third-party cookies in the browser. Microsoft Learn lists blocked third-party cookies as a cause of Cloud Shell startup failures.
    • If the issue is tied to remote access to a lab VM, verify that outbound RDP/SSH traffic is not being blocked by the local firewall, router, or network. Azure Lab Services notes that firewalls and some routers can restrict ports 3389/22.
    • If the lab VM was modified by an administrator or student, a reimage can return it to a known-good state. Warning: reimaging deletes all user data on the VM. To avoid data loss, store user data outside the lab VM, such as with OneDrive.
    If the issue is specifically a Microsoft Learn training lab rather than a directly managed Azure Lab Services lab, the documented Learn-side actions are limited to browser/session troubleshooting such as private browsing, clearing cache/cookies, and enabling third-party cookies for Cloud Shell. Since those have already been exhausted, escalation is the documented path.
  2. Nathan Roberts (SN) 13,616 Reputation points Student Ambassador Volunteer Moderator
    2026-07-24T11:19:04.6233333+00:00
    Please can we stick to one thread on the Q&A community. I know you said that the solutions haven't helped, but it allows everything to be in one place. This helps the community to be able to help you effectively as they can see what has already been suggested without having to flick between threads. Your other threads are here:
    1. https://learn.microsoft.com/en-us/answers/questions/5955061/the-lab-remains-stuck-on-loading-lab-across-chrome,
    2. https://learn.microsoft.com/en-us/answers/questions/5953320/microsoft-learn-lab-stuck-loading,
    When reading one of your questions, it has allowed me to answer one of my questions I was going to ask you, which was what module are you having problems with. You have stated in the first post it is this module: https://learn.microsoft.com/en-us/training/modules/power-bi-effective-reports/9-lab?source=learn
    I am going to mark your other questions as duplicate, pointing them to this thread. I also tried launching multiple Microsoft Learn labs.
    Loading lab...
    When loading up that training module, I see the same problem with my account.
    Please can you provide feedback to the Learn module team by reporting feedback here: reporting an issue
    Please scroll down to the section with a heading "Report feedback"
    This will allow you to submit feedback to the module team who can review the feedback and act on it.
    In the meantime, please continue to use the learning lab on GitHub for the PowerBI desktop.
    Hope this helps,
    Nathan
