Interface not registered error on Paint, Notepad, Outlook and crossdeviceresume.exe
Andy Cannon 21 Reputation points
2026-07-23T10:07:21.14+00:00
Interface not registered error on Paint, Notepad, Outlook and crossdeviceresume.exe from the Windowsapps folder.
Example:
[Window Title]
C:\Program Files\WindowsApps\Microsoft.Paint_11.2605.71.0_x64__8wekyb3d8bbwe\PaintApp\mspaint.exe
[Content]
[OK]
We have this error on several machines for different clients and I'm having a hard time identifying what is causing the issue. They are all Home x64 Edition Build 26200, all up to date.
So far I've run:
Dism /Online /Cleanup-Image /ScanHealth
Dism /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-image /RestoreHealth
SFC /SCANNOW
Get-AppXPackage -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
And installed both X64 and X32 versions of the Visual C++ v14 Redistributable on another forum's recommendation.
This started happening on all the machines in early July.
thanks
Andy
Windows for home | Windows 11 | Apps
Lucus-V 13,115 Reputation points Microsoft External Staff Moderator
2026-07-23T15:49:51.6333333+00:00
Hi Andy Cannon,
Based on the symptoms and the troubleshooting already completed, this does not look like a Paint-specific issue. The key indicator is that multiple Microsoft Store/packaged applications (Paint, Notepad, Outlook, and CrossDeviceResume) are all failing with the same "Interface not registered" error on multiple Windows 11 devices.
You may try some suggestions bellow:
  • Test with a New User Profile
    Create a local test account and verify whether the affected apps launch there. If they do, the problem may be isolated to the user profile rather than the operating system itself.
  • Perform an In-Place Repair / Reinstall of the Current Windows Version
    Reinstall the current version of Windows following this article: Fix issues by reinstalling the current version of Windows.
  • Uninstall Recent Windows Updates
    Since the issue reportedly began across multiple machines in early July, I would review installed updates and test removing the most recently installed cumulative update on an affected machine to determine whether the problem was introduced by a specific update.
If you have further information, please feel free to let me know.
1 additional answer
  1. Andy Cannon 21 Reputation points
    2026-08-06T10:39:44.44+00:00
    This fixed it for the all the affected machines we found:
