Due Amount Payment Issue
Stavya Spine Hospital 0 Reputation points
2026-07-23T07:52:36.2533333+00:00
Your payment could not be processed because your financial institution declined your card. A past due balance from last month is still pending, which is preventing the current payment from being completed. Please clear the outstanding amount and update your payment method to proceed. Give me solution to overcome this issue
SAP HANA on Azure Large Instances
Microsoft branding terminology for an Azure offer to run HANA instances on SAP HANA hardware deployed in Large Instance stamps in different Azure regions.
    2026-07-23T07:53:19.3733333+00:00
    To resolve this past-due payment issue:
    1. Confirm the card can be charged.
      • Contact the bank or card issuer.
      • Verify that the card has sufficient funds or available credit.
      • Verify that international transactions are enabled.
      • Verify that recurring payments are enabled.
    2. Clear the outstanding balance first.
      • A past-due balance can block the current payment until the overdue amount is paid.
      • If using Azure, clear any outstanding balances before deleting or replacing the payment method.
    3. Retry the payment or use a different card.
      • If the current card was declined, try the payment again after the bank confirms the card is allowed.
      • If needed, use another payment method.
    4. If the browser is causing problems while updating the payment method:
      • Sign out of all active Azure sessions.
      • Open an InPrivate session in Microsoft Edge or Internet Explorer.
      • Try updating the payment method again.
      • If needed, refresh the browser, use another browser, or delete cached cookies.
    5. In Microsoft 365 business billing, pay the overdue amount from the admin center.
      • Go to the Microsoft 365 admin center.
      • Open Subscriptions > View invoices in Simplified view, or Billing > Bills & payments in Dashboard view.
      • Open the invoice with the warning.
      • Select Pay your balance.
      • Choose to retry the same payment method, use another one, or add a new one.
      • Review and submit the payment.
    6. If the payment method still cannot be updated or every card fails validation, open a billing support request from the Microsoft 365 admin center under Support > Help & Support.
