Alternative System-Level Methods to Retrieve Tenant ID on Intune MDM-Only Enrolled Device
Sivabalan J 20 Reputation points
2026-07-23T05:22:37.72+00:00
I have few machines enrolled in Microsoft Intune using the "Enroll only in device management" enrollment method, and need to retrieve the Tenant ID programmatically for device identification.
I am aware of retrieving the Tenant ID from the user certificate store:
%APPDATA%\Microsoft\SystemCertificates\My\Certificates
Extract the OID 1.2.840.113556.5.14 (tenantId) from the certificate whose thumbprint matches the value of HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Enrollments{EnrollmentGUID}\dmpCertThumbprint
This approach requires access to a specific user account's certificate store and is not suitable for system-level or service account scenarios.
I am looking for alternative system-level methods to obtain the Tenant ID on a device enrolled in "Enroll only in device management" mode example: Registry keys at HKEY_LOCAL_MACHINE
https://learn.microsoft.com/en-us/answers/questions/5768194/tenant-id-location-for-intune-only-enrolled-device
https://msendpointmgr.com/2024/10/12/unpacking-the-microsoft-intune-mdm-certificate/
Microsoft Security | Intune | Other
    2026-07-23T05:22:58.6866667+00:00
    For Intune MDM-only enrollment, the supported local options in the provided material are:
    1. Check the Workplace Join tenant registry location:
      • Open Registry Editor.
      • Go to: HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WorkplaceJoin\TenantInfo
      • The subkey name under TenantInfo is the tenant ID.
      • If it is not present there, check the same path under: HKEY_LOCAL_MACHINE
    2. Use dsregcmd /status:
      • Run from Command Prompt.
      • Review the User State section.
      • WorkplaceJoined : YES confirms the connected workplace account context.
    There is no official registry path in the provided material that confirms a separate machine-wide Intune MDM-only tenant ID location beyond the Workplace Join paths above.
    For enrollment behavior, Microsoft Entra-integrated MDM enrollment passes the discovery URL from Azure directly to the system, and for a user-owned device where a work account is added, MDM enrollment is not mandatory and can be declined. The enrolled certificate type in that model is a user certificate, not a device certificate. That aligns with why user-context artifacts can appear for this enrollment style instead of a clearly exposed system-wide tenant ID location.
    If a program must run entirely as LocalSystem or a service account, the provided material does not document another supported system-only method to retrieve the tenant ID locally for Intune MDM-only enrollment.
