Surface laptop 1st generation not powering on
Lisa Fulks 0 Reputation points
2026-07-22T22:39:32.1+00:00
My surface laptop (model 1943) will not power on after dien. I thought my charger was the issue & I bought a new one & still nothing. The light on the charger is solid white. Any ideas on what the issue is?
Surface | Surface Laptop | Power and battery
    2026-07-22T22:39:49.06+00:00
    A solid white charger light means the Surface detects the power supply. In that case, the next checks are for startup or battery detection rather than the charger itself.
    Try this in order:
    1. Disconnect everything from the Surface.
      • Remove any USB devices, SD cards, external monitors, Type Cover, and disconnect it from any Surface Dock.
      • Accessories can prevent startup.
    2. Charge it with the Surface power supply for at least 15 minutes.
      • Since the charger light is solid white, leave it connected, then close and reopen the lid or keyboard and press the power button.
    3. Try the wake shortcut.
      • If a keyboard is connected or integrated, press Windows logo key + Ctrl + Shift + B.
    4. Force a restart.
      • Press and hold the power button until the logo screen appears (about 20 seconds).
    5. If it still does not start, the charger is less likely to be the problem.
      • A solid white light with no power-on points to the Surface itself, or possibly the battery/startup path.
    6. If Windows does start later but the battery shows an X and the device turns off when unplugged, start a service request.
    7. If the Surface remains completely unresponsive after the steps above, use Surface service options.
  2. S.Sengupta 32,031 Reputation points MVP Volunteer Moderator
    2026-07-23T00:28:32.7833333+00:00
    A solid white light on the Surface Connect charger usually means the charger is receiving power and is properly connected to the laptop. Since you've already tried a new charger, the problem is more likely with the laptop itself than the power adapter.
    Disconnect everything (USB devices, external monitor, SD card, etc.), leave only the charger connected, then:
    Hold the Power button for 30 seconds.
    Release it.
    Wait 10 seconds.
    Press the Power button once.
    If there is no logo, no fan, no keyboard backlight, and no response whatsoever, despite the charger LED staying white, the issue is likely an internal hardware fault that will require repair. The most likely causes are an internal power issue, battery failure, or motherboard failure.
