Read aloud not working in edge and is grayed out
SM-4342 20 Reputation points
2026-07-22T17:41:01.45+00:00
Hi there, one day ago the read aloud feature in edge was working fine. but then it would change by itself to another language and now it is not working at all.
This is what i have done so far to fix this:
Issue
Read Aloud in Microsoft Edge fails to play audio when I am signed into my Microsoft account, but it works fine on Guest or signed-out profiles.
What I Have Already Tried
  • Basic Fixes: Signed out and back in; reset Edge settings to default; reset cloud profile sync.
  • Profile & Data Repairs: Closed all Edge background processes and rebuilt the local profile data folder (%localappdata%\Microsoft\Edge\User Data); tested creating a fresh Edge profile.
  • Voice & System Settings: Tried switching between Natural (online) voices and local Windows offline voices; tested using Immersive Reader mode (F9).
  • Network & App Repairs: Disconnected/reconnected account in Windows Settings; flushed DNS and reset network sockets via Command Prompt; ran the Microsoft Edge Repair tool in Windows Apps.
But nothing has worked, at first the local voices did work but now i am unable to select anything as it is grayed out.
my windows version:
And also read aloud works in an account that i have not signed into, but that is not feasible for me.
Please assist i really need this to work.
Microsoft Edge | Audio and video playback | Windows 11
Clary-N 15,730 Reputation points Microsoft External Staff Moderator
2026-07-22T23:43:59.0966667+00:00
Since this is a public forum, we will hide your personal identifiable information, and I have sent that image of yours containing your personal identifiable information in a private message so we can work together to resolve the issue. Also, please check your private message in case you want to share another screenshot to avoid leaking your PII by click on the Private Message button as show below
Hi SM-4342,
Thank you for providing the detailed troubleshooting information and for confirming that Read Aloud works correctly in Guest mode and in profiles that are not signed in to your Microsoft account.
Based on the information shared, this does not appear to be a general Windows audio issue or a Microsoft Edge installation problem. Since the feature works in other Edge profiles but fails when you are signed in, the issue may be related to the affected Edge profile, synchronized account data, or the Read Aloud service associated with that profile.
Before contacting Microsoft Support, you may also consider testing in a new Windows user account. If the same behavior occurs after signing into Edge with the affected Microsoft account, this will help confirm that the issue is not limited to the current Windows user profile and may instead be related to the Edge profile, synced data or an account-related service issue:
  1. Open Settings > Accounts > Other users.
  2. Select Add account.
  3. Choose I don't have this person's sign-in information > Add a user without a Microsoft account.
  4. Create a temporary local user account and sign in to that account.
  5. Open Microsoft Edge and sign in with the same Microsoft account that is experiencing the issue.
  6. Test whether Read Aloud works normally and whether the voice selection remains available.
To obtain further assistance and determine whether there is an ongoing issue affecting the Read Aloud feature or account-related services, I recommend contacting Microsoft Support directly:
  1. Go to Contact Microsoft Support and sign in with your Microsoft account.
  2. Type "Chat Support" and select Get help.
  3. Scroll down and select Contact support.
  4. Under Products and services, choose Microsoft Edge (or Windows if Edge is not available).
  5. Under Category, select Technical support, then select Confirm.
  6. Choose Chat with a support agent in your web browser.
Kindly note that this is a user-to-user support forum. Moderators and contributors do not have access to Microsoft's internal systems, Edge synchronization data, service health information or backend logs. As a result, Microsoft Support may be better positioned to investigate whether there is a known issue affecting Read Aloud, review account-related data, check for any service-side problems and advise on any available workarounds or next steps.
I understand how important this feature can be, especially since it was working previously and I hope the support team can provide more insight and help resolve the issue.
Thank you for your understanding.
Best regards.
If you have extra questions about this answer, please click "Comment".
0 additional answers
