How do I create a path?
D'Souza, Moses K 0 Reputation points
2026-07-21T14:06:15.1233333+00:00
When I try to add a course to a path, it says I don't have a path yet, how do I go about creating one?
Azure | Azure Training
    2026-07-21T14:06:31.6666667+00:00
    To create a learning path in Viva Learning:
    1. Go to the Admin tab in Viva Learning.
    2. Select Learning path from the left menu.
    3. Select Create new.
    4. Enter a title and description.
    5. Optionally upload a thumbnail or choose a default one.
    6. Select Create.
    7. Select Add content to add courses or other learning content.
    8. Optionally add section titles and descriptions, then reorder content by dragging items.
    9. Select Save.
    The learning path is saved as a draft. From there, it can be edited, previewed, or published.
    Requirements:
    • A premium license for Viva Learning or Viva Suite is required.
    • Admin or knowledge manager permissions are required to create a learning path.
    If the message says no path exists yet, the account likely does not have an existing learning path and must create one from the Admin tab first.
