A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
If clicking Repair Now simply closes PowerPoint and the same error appears the next time you open it, the built-in repair prompt may not be completing successfully. This issue is often related to a corrupted Office installation, an add-in, or a problem with the local Office profile.
You can try:
Start PowerPoint in Safe Mode: Press Windows + R > Type powerpnt /safe> Press Enter (Open Office apps in safe mode on a Windows PC | Microsoft Support)
If PowerPoint opens in Safe Mode, disable any add-ins:
- File > Options > Add-ins > Select COM Add-ins > Go > Clear all add-ins and restart PowerPoint.
Run an Online Repair of Microsoft 365:
- Open Control Panel > Programs and Features > Select Microsoft 365
- Click Change/Modify > Choose Online Repair. (Repair an Office application | Microsoft Support)
If the issue continues, completely uninstall Microsoft 365, restart the computer, and reinstall it using the education account associated with the license.
Uninstall Microsoft 365 or Office from a PC - Microsoft Support
Download, install, or reinstall Microsoft 365 or Office 2024 on a PC or Mac - Microsoft Support
Please try the steps above and let me know if they work via comment section. I look forward to your response.
If the answer is helpful, please click "Yes''. If you have extra questions about this answer, please click "Comment".
