"Could not load file or assembly" error in Visual Studio designer.
McDonald, Gregor 0 Reputation points
2026-07-20T23:08:48.16+00:00
I am getting a "Could not load file or assembly" error in the Visual Studio designer for a WinForms app, when the file in question (a custom DLL) most definitely exists, and in the directory that it is supposed to be.
Developer technologies | Windows Forms
    2026-07-20T23:09:08.9533333+00:00
    For a WinForms designer error like "Could not load file or assembly" when the DLL is present, the supported fixes are:
    1. Clean and rebuild the project or solution
      • In Solution Explorer, right-click the project or solution and select Clean.
      • Then right-click it again and select Rebuild.
      • The designer often fails to load when the project is not building cleanly.
    2. Delete the bin and obj folders
      • Close the designer first.
      • Delete the project’s bin and obj folders.
      • Reopen the solution and build again.
      • This can clear temporary files or force restore behavior that fixes a bad dependency.
    3. Verify the assembly reference is actually resolved by the project
      • The designer error page states that when a class or assembly cannot be loaded, Visual Studio may require the class to be referenced in the project.
      • If the custom DLL is used by a base class or control, make sure that reference is added correctly and then close and reopen the Windows Forms Designer.
    4. Use the designer error page details
      • In the designer error window, expand the yellow error bar and check:
        • file name
        • line and column
        • error code
        • description
        • Show Call Stack if available
      • This helps identify whether the failure is in code-behind, a dependency, or a designer-loaded type.
    5. If the problem is with an inherited form or base class, build first
      • If the form derives from another form or control, the designer may fail until all projects are built and the base class can be loaded.
    6. If the assembly targets x64 and the issue is with inherited forms, check platform targeting
      • A documented case shows the Windows Forms Designer can fail to display an inherited form when the base form is defined in a 64-bit assembly.
      • In that scenario, the designer reports that the base class could not be loaded even though the assembly exists.
    7. If the error comes from a third-party component, treat it as a component issue
      • Several designer load failures are documented as third-party component problems rather than a Visual Studio file-location problem.
    If the DLL is physically present but the designer still cannot load it, the most supported interpretation is that the designer cannot resolve or use that assembly in the current design-time context, not that the file is missing from disk.
  2. Nancy Vo (WICLOUD CORPORATION) 8,155 Reputation points Microsoft External Staff Moderator
    2026-07-21T04:07:08.69+00:00
    Hello @McDonald, Gregor ,
    Thanks for your question.
    The Could not load file or assembly error may occur even when the file is present because the system is struggling to read it, rather than find it.
    You can refer to these following workarounds:
    • Older versions of Visual Studio (2019 and below) run as 32-bit processes. If the DLL is compiled strictly as 64-bit (x64), the designer may fail to load it. You might consider changing the Platform Target in your project's Build properties to Any CPU or x86.
    • Windows sometimes blocks external files for security reasons. You can check this by right-clicking the DLL in File Explorer, selecting Properties, and looking for an Unblock checkbox at the bottom of the General tab.
    • The error may indicate that a secondary file your custom DLL relies on is missing. It is worth verifying that all required background libraries are included in the same directory.
    • Visual Studio may be trying to read an older, broken copy of the file. It could be helpful to close Visual Studio, delete the bin and obj folders in your project directory, and rebuild the solution.
    I hope this addresses your question. If this response was helpful, please consider following the guidance to provide feedback. Thank you.
