Multiple login dialogs every time I use Edge
Wayne Gutekunst 0 Reputation points
2026-07-19T19:32:40.5566667+00:00
Every time I launch Edge I get a login dialog to enter my password. The password I setup is not valid. Changed the password successfully (got confirmation that it was changed). Entered new password in dialog box, password is invalid. When I login to my MS Account from the website, login is successful using pin. I'm getting the login box every time I use Edge. Sometimes I get a request to login to OneDrive in. When I enter One Drive in the browser, everything is ok and it logs in. Still get the login Dialog for OneDrive.
Microsoft Edge | Open the browser | Windows 11
  1. Alex-L 12,555 Reputation points Microsoft External Staff Moderator
    2026-07-20T13:50:06.0033333+00:00
    Hi Wayne Gutekunst
    It sounds like Edge is trying to re-authenticate your Microsoft account, but the credentials stored in Windows may be out of sync. Since you can sign in to your Microsoft account and OneDrive normally, the issue may be with cached credentials rather than the account password itself.
    You could try:
    1. Sign out of Edge completely (Settings > Profiles), close Edge, then sign back in.
    2. Open Windows Settings > Accounts > Email & accounts and remove/re-add the affected Microsoft account if it appears there.
    3. Open Credential Manager (Control Panel > Credential Manager > Windows Credentials) and remove Microsoft/Edge/OneDrive-related cached credentials, then restart Windows.
    4. Ensure Windows is fully updated and try an Edge Repair: Settings > Apps > Installed Apps > Microsoft Edge > Modify > Repair.
    5. Create a new Edge profile temporarily to see if the issue is profile-specific.
    If the problem continues, please let us know:
    • Whether you're using a personal Microsoft account or a work/school account.
    • Whether the password prompt is coming from Edge, Windows Security, or OneDrive.
    • If any error code accompanies the “Invalid Password” message.
    Feel free to update here if anything comes up!
    If this answer was helpful, please click "Accept Answer" and vote for it. If you have additional questions regarding this answer, please click "Comment".
    Note: Please follow the steps outlined in our documentation to enable email notifications if you wish to receive notifications regarding this discussion.
