Edge Read Aloud Online Voice Options consistently glitching out to all be the same "Microsoft undefined Online (Natural) - undefined"
Anthony Bose 10 Reputation points
2026-07-19T15:31:13.9233333+00:00
The issue just started happening 5 days ago. I've already reset all Edge settings and still same issue. I run speed tests and they show my internet is running fine.
Microsoft Edge is up to date.
Version 150.0.4078.83 (Official build) (64-bit)
Microsoft Edge | Audio and video playback | Windows 11
  1. nobuko c 125.1K Reputation points Independent Advisor
    2026-07-19T20:27:05.1066667+00:00
    Please create a new profile in Microsoft Edge and test whether the Read Aloud feature works correctly there.
    In the Edge address bar, enter:
    edge://settings/profiles
    and press Enter.
    Click “Add profile” and test Read Aloud in the new profile.
    If the issue does not occur in the new profile, the cause is a corrupted Edge profile, which cannot be repaired by resetting Edge. In that case, please consider migrating to a new profile.
    How to migrate your profile:
    1. In the Edge address bar, enter:
    If you are not signed in with your Microsoft account, please sign in.
    Make sure all sync options are turned ON and wait until synchronization is fully completed.
    1. Sign out of your Microsoft account from the old profile.
    2. In the new profile, open:
    Sign in with your Microsoft account again.
    Turn all sync options ON and wait until synchronization is fully completed.
    Your profile migration is now complete.
    Favorites, extensions, and other data will be synchronized to the new profile.
  2. Fathered Puma 0 Reputation points
    2026-07-20T10:20:29.23+00:00
    Your only option is to hope Microslop fixes it one day (they don't like fixing bugs in my experience so I wouldn't get your hopes up). You can already find numerous posts going back a few days about this so no hotfix for certain.
    In the meantime you have 2 options:
    1. Create a new profile and swap between them every time it breaks.
    2. What I'm doing: Download the Microsoft Edge Beta and copy your %LOCALAPPDATA%\Microsoft\Edge\User Data\Default Folder to %LOCALAPPDATA%\Microsoft\Edge Beta\User Data\Default and swap between those to keep all your extensions, scripts, and settings synced. I think you can do this with Profile's to but meh already had Beta downloaded and no it doesn't fix it.
    3. Hidden 3 option: Find a better TTS solution so you can uninstall Edge and please share it with us.
