Microsoft Store issue (blank interface and nothing opening)
Nishchal Pandey 40 Reputation points
2026-07-18T12:28:12.6166667+00:00
My microsoft store in snot opening, every time I try to open, it always shows blank screen and doesn't open at all.
I tried everything, no vpns connected, nothing
  1. "wsreset.exe" to reset it,
  2. Running troubleshooter but it shows error of "hanging and crashing apps"
  3. Also I Checked for System File Corruption, "sfc /scannow" and "DISM /Online /Cleanup-Image /RestoreHealth"
  4. Also I Re-registered Microsoft Store via PowerShell using this command "Get-AppXPackage WindowsStore -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}"
but nothing happens, it's still not opening.
Kindly advise some solution as I am not able to use anything, Thanks!
Windows for home | Windows 11 | Microsoft Store
TaoLi 112.4K Reputation points Independent Advisor
2026-07-21T13:24:37.84+00:00
Thanks for testing all the steps. Since you already performed Windows 11 25H2 repair reinstall and Microsoft Store is still showing a blank screen, this is likely not a Store app package issue.
From your log, the important clue is:
net start wlidsvc
System error 5 has occurred. Access is denied.
Microsoft Account Sign-in Assistant (wlidsvc) is required by Microsoft Store for account authentication. Please try repairing its permissions:
Open Command Prompt as Administrator.
Run these commands one by one:
sc sdset wlidsvc D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)(A;;CCLCSWRPWPDTLOCRRC;;;AU)
Restart the PC, then run:
net start wlidsvc
If the service starts successfully, test Microsoft Store again.
Ramesh 181.6K Reputation points Volunteer Moderator
2026-07-20T08:03:59.4133333+00:00
A repair installation via Settings should help. See Fix issues by reinstalling the current version of Windows | Microsoft Support
2 additional answers
  1. TaoLi 112.4K Reputation points Independent Advisor
    2026-07-18T13:04:31.37+00:00
    Since wsreset, SFC/DISM and PowerShell re-registration did not help, please try these steps instead:
    Press Win + R, enter services.msc, and make sure Microsoft Store Install Service, Client License Service (ClipSVC), AppX Deployment Service (AppXSVC), and Windows Update are not disabled. Leave them at their default Manual/Trigger Start setting.
    If it still fails, create a temporary local administrator account. Go to Settings > Accounts > Other users > Add account, select “I don’t have this person’s sign-in information” > “Add a user without a Microsoft account”, then create the account. After that, select the new account > Change account type > Administrator. Sign out, log in to the new account, and test Microsoft Store.
    If the Store is also blank in the new account, go to Settings > System > Recovery > Fix problems using Windows Update > Reinstall now. This repairs Windows system components while keeping your files, installed apps and settings:
    https://support.microsoft.com/en-us/windows/deployment/install-upgrade/fix-issues-by-reinstalling-the-current-version-of-windows
  2. TaoLi 112.4K Reputation points Independent Advisor
    2026-07-21T12:31:37.8333333+00:00
    Thank you for the command output. It reveals the likely root cause: the Microsoft Account Sign-in Assistant service (wlidsvc) cannot start because of “System error 5: Access is denied.” The Store blank screen is probably only a symptom of this damaged service configuration.
    The commands you ran successfully repaired the wlidsvcconfig.xml permissions, but they did not restore the service’s complete registry configuration. Please create a restore point first, then use the wlidsvc service repair file provided in this guide, restart Windows, and run net start wlidsvc again:
    https://www.winhelponline.com/blog/wlidsvc-sign-in-0x80070005-1297-errors/
    Disclaimer: This link points to a non-Microsoft official website. The page content appears accurate and safe, but the website may contain third-party advertisements. Please distinguish between advertisements and official download links to avoid accidentally clicking on content that may promote PUPs/PUAs (potentially unwanted programs). Before downloading or installing any files, it is recommended to verify the source and file name.
    This specific repair has resolved the same wlidsvc access-denied problem for other Windows 11 users.
